[mapserver-users] Yellow lines over generated image (SOLVED)
Pete Deffendol
pete at mdsc.com
Fri Sep 16 00:53:32 EDT 2011
On Sep 15, 2011, at 12:56 PM, Steve Lime wrote:
> Cool effect... Is this AGG output? Do the lines persist if you create the map with shp2img?
This is AGG output. I have managed to solve the problem by making some changes to the OUTPUTFORMAT section of the mapfile that has worked fine for us for years. Here is the original block:
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
And here is the new block:
OUTPUTFORMAT
NAME png
DRIVER "AGG/PNG"
IMAGEMODE RGBA
EXTENSION "png"
TRANSPARENT OFF
END
I hope there's nothing out of the ordinary there, but it works for me, so I'm moving on.
Pete
Pete Deffendol
Senior Web Developer
Multimedia Data Services Corp.
pete at mdsc.com
Phone: 435-227-5465
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110915/dfad2f67/attachment.html
