[mapserver-users] Text outline not working on line features
Bistrais, Bob
Bob.Bistrais at maine.gov
Tue Sep 20 16:56:36 EDT 2011
This is an older version of MapServer, MS4W 2.3.1, MapServer 5.2.1.
Using a global file with the outputformat params:
OUTPUTFORMAT
NAME 'agg/png'
DRIVER AGG/PNG
IMAGEMODE RGBA
FORMATOPTION "TRANSPARENT=TRUE"
END
OUTPUTFORMAT
NAME 'print'
DRIVER "GD/GIF"
MIMETYPE "image/gif"
IMAGEMODE PC256
EXTENSION "gif"
TRANSPARENT ON
END
-So we're going to gif on the printout.
Not sure what you meant by label output. But here's what I see- on the
web application, the labels are as they should be- they have the
background halo. On the printed map, the label text itself appears, but
no background halo.
Yes, I'm absolutely sure that's the code being used in the .map file.
-----Original Message-----
From: Stephen Woodbridge [mailto:woodbri at swoodbridge.com]
Sent: Tuesday, September 20, 2011 1:49 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Text outline not working on line features
Bob,
Also, what are you getting for label output in you case? More info would
help diagnose this.
Thanks,
-Steve W
On 9/20/2011 1:47 PM, thomas bonfort wrote:
> what mapserver version, what outputformat?
> regardless, it should work with any version, are you sure that this is
> the actual mapfile snippet that is being used ?
> thomas
> On Tue, Sep 20, 2011 at 18:45, Bistrais, Bob<Bob.Bistrais at maine.gov>
wrote:
>> I'm trying to draw and label road features from a shapefile. I'd
like to
>> include an outline of the road name text as a halo. This works fine
on
>> polygon and point features, but is not working for me with the line
>> features.
>> Here is the code block:
>> LABEL
>> ANGLE auto
>> PARTIALS false
>> FORCE false
>> MINDISTANCE 250
>> POSITION uc
>> COLOR 200 0 0
>> OUTLINECOLOR 255 255 255
>> OUTLINEWIDTH 5
>> FONT "verdana"
>> SIZE 12
>> TYPE truetype
>> END
>> TEXT ([RDNAME])
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
