Re: Σχετ: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Sep 22 09:38:45 EDT 2011
I can repeat this problem with Mapserver 6.0.1 on Windows Vista 32-bit. I defined one PostGIS test layer without metadata and GetCapabilities fails after a long waiting. With DEBUG 5 the last line in MS_ERRORFILE that appears is this
msPostGISLayerIsOpen called.
Adding "wms_extent" corrects the situation. Same mapfile does work on Linux and it used to work for me on Windows too with Mapserver 5.x.
-Jukka Rahkonen-
Lähettäjä: Andreas Douvalis [mailto:anddreas2 at yahoo.gr]
Lähetetty: 22. syyskuuta 2011 10:14
Vastaanottaja: Rahkonen Jukka
Aihe: Σχετ: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
No problem with pgsql
<!--[if !supportLineBreakNewLine]-->
<!--[endif]-->
It takes 78 ms the sql of the layer that it doesn't work with wms get map request.
Unfortunately there is no debug error to check the query that mapserver runs.
Απο: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi>
Προς: 'anddreas2' <anddreas2 at yahoo.gr>; "'mapserver-users at lists.osgeo.org'" <mapserver-users at lists.osgeo.org>
Στάλθηκε: 9:32 π.μ. Πέμπτη, 22 Σεπτεμβρίου 2011
Θεμα: Re: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
Basically it means that the SQL query for getting the extents of your layer is slow.
Set timing on with \timing on in your psql window and run query
select st_extent(geom) from titles;
http://postgis.refractions.net/docs/ST_Extent.html
How long does it take? Do vacuum analyze for the table and try again to see if there has been some trouble with indexes.
Anyway, it is always faster to get extents from the metadata line than from PostGIS, but normally it should not take very long. For me it takes 1500 ms with a table of 300000 polygons.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>
> [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] Puolesta anddreas2
> Lähetetty: 22. syyskuuta 2011 8:52
> Vastaanottaja: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Aihe: [mapserver-users] Re: Mapserver 6 WMS / PostGIS Problem
> I found the solution:
> Just set THE wms_extent METADATA in the layer section and it
> works. Without
> Layers wms_extent it crashes.
> (Jesus, I spent three days of my life for this stupid thing.
> I tested with
> all versions of postgis (1.5, 1.4) postgresql (8.4,9.0,9.1).
> I am think it
> is ms4w problem).
> http://osgeo-org.1803224.n2.nabble.com/Mapserver-6-WMS-PostGIS
> -Problem-tp6387007p6819004.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110922/fe4f5f62/attachment-0001.html
