[mapserver-users] PHP Mapscript - debugging help
Ian Walberg ian.walberg at airborne.aero
Mon Sep 26 13:54:37 EDT 2011
Hello,
We have moved from 5.x to 6.x are chasing an issue causing a
segmentation fault which appears to be related to the way we are
defining the symbols.
If we create the map object from an empty map file (with just MAP and
END in it) then we do not get a segmentation fault, sounds like
something not initialized I know...
Any ideas on this appreciated but here is the real question (and it may
really be a php question)  :-
We used to print_r the map object and then compare the one created from
the map file and the one we had created programmatically, however with
mapserver 6.x the print_r on the map object is empty.
I am sure this is basic PHP but any help would be appreciated.
Thanks
Ian
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20110926/579d629b/attachment.html
