[mapserver-users] Validation error (but working!)
Ben Madin
lists at remoteinformation.com.au
Mon Apr 2 02:39:51 EDT 2012
G'day all,
I've noticed that when I turn layer (going out as a WMS service) debugging on, I am getting the messages shown below (the layer is rendering as I expected, with only the names for the selected country showing up).
As I said, it is working, but what is wrong with my patterns - I suspect other layers with the same validation patterns would be giving the same errors, but I haven't investigated them (as they are working)
My confusion is :
Either the validation is working (and the log message is wrong), or
I am failing to understand how the validation is meant to work, or
The validation is failing, but not being respected…
any clues
cheers
Ben
Log messages :
[Mon Apr 2 14:29:40 2012].960342 runtime substitution - Layer provnames, tag %CCODE%...
[Mon Apr 2 14:29:40 2012].960725 msValidateParameter(): Regular expression error. Parameter pattern validation failed.
[Mon Apr 2 14:29:40 2012].960759 msValidateParameter(): Regular expression error. Parameter pattern validation failed.
[Mon Apr 2 14:29:40 2012].960775 runtime substitution - Layer provnames, tag %YEAR%...
[Mon Apr 2 14:29:40 2012].961353 msDrawMap(): rendering using outputformat named AGG (AGG/PNG).
[Mon Apr 2 14:29:40 2012].993291 msPostGISLayerIsOpen called.
The layer has a validation pattern and defaults set:
METADATA
"wms_title" "provnames"
"wms_srs" "EPSG:4326"
"wms_group_title" "Administrative"
"default_ccode" "AUS"
"default_year" "2010"
END
VALIDATION
'ccode' '[A-Z]{3}'
'year' '20[0-1][0-9]'
END
and the query is :
DATA "geom from (
SELECT recordid as gid, geom, name as pname
FROM geolayer
WHERE validitystarts <= '%YEAR%'
AND (validityends >= '%YEAR%' OR validityends IS NULL)
AND country LIKE '%CCODE%'
) AS foo USING UNIQUE gid USING SRID=4326"
TYPE ANNOTATION
labelmaxscaledenom 5000000
LABELITEM pname
CLASS
LABEL
COLOR 150 150 250
OUTLINECOLOR 255 255 255
FONT "lucida"
TYPE truetype
SIZE 9
POSITION AUTO
PARTIALS FALSE
END
END
and the version is :
MapServer version 6.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=CAIRO SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
