[mapserver-users] GetFeatureInfo results: Search returned no results
Neelima Emmani
neelima.emmani at iictechnologies.com
Tue Apr 10 02:02:14 EDT 2012
Hi All,
I am having a problem in retrieving getfeatureinfo. Result in the browser is
GetFeatureInfo results: Search returned no results.
* Below is the url, i am accessing to get feature info -
http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/mh.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&Layers=maps&SRS=EPSG:4326&BBOX=-83.61145,24.726875,-78.118286,27.196014&X=529&Y=228&WIDTH=1000&HEIGHT=500&QUERY_LAYERS=maps
* Map file -
MAP
NAME "MH"
# Map image size
SIZE 600 600
UNITS meters
EXTENT -86.731680 24.422064 -76.149835 30.424575
FONTSET './etc/fonts.txt'
SYMBOLSET './etc/symbols.txt'
CONFIG "PROJ_LIB" "C:/ms4w/httpd.d/proj/nad/"
PROJECTION
'proj=longlat'
'ellps=WGS84'
'towgs84=0,0,0,0,0,0,0'
'no_defs'
END
# Background color for the map canvas -- change as desired
IMAGECOLOR 255 255 255
IMAGEQUALITY 95
IMAGETYPE agg
OUTPUTFORMAT
NAME agg
DRIVER AGG/PNG
IMAGEMODE RGB
END
# Legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Web interface definition. Only the template parameter
# is required to display a map. See MapServer documentation
WEB
# Set IMAGEPATH to the path where MapServer should
# write its output.
IMAGEPATH '/ms4w/tmp/ms_tmp/'
# Set IMAGEURL to the url that points to IMAGEPATH
# as defined in your web server configuration
IMAGEURL '/ms_tmp/'
# WMS server settings
METADATA
'ows_title' 'MH'
'ows_onlineresource' 'http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/mh.map&'
'ows_srs' 'EPSG:4326 EPSG:900913'
'ows_enable_request' 'GetMap GetFeature GetFeatureInfo *' ##necessary
"wms_feature_info_mime_type" "text/html"
"wms_getfeatureinfo"
"http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/openlayers-2.10/examples/mh.map&"
"wms_featureinfoformat" "text/html"
"wfs_abstract" "This text describes my WFS service."
END
#Scale range at which web interface will operate
# Template and header/footer settings
# Only the template parameter is required to display a map. See MapServer documentation
TEMPLATE 'template.html'
END
LAYER
NAME 'maps'
TYPE POINT
DUMP true
HEADER 'header.html'
FOOTER 'footer.html'
CONNECTIONTYPE postgis
CONNECTION "dbname='postgis' host=localhost port=5432 user='postgres' password='xxxxxx' sslmode=disable"
DATA 'the_geom FROM "maps" USING UNIQUE id USING srid=4326'
FILTER ( geometrytype("the_geom") IN ('POINT','MULTIPOINT') )
METADATA
'ows_title' 'maps'
'wfs_typename' 'maps'
'wfs_version' '1.0.0'
'wfs_connectiontimeout' '60'
'wfs_maxfeatures' '150'
'wfs_filter' 'GET'
'wms_include_items' 'all'
'wfs_featureid' 'the_geom'
'gml_include_items' 'all'
END
STATUS OFF
TRANSPARENCY 100
PROJECTION
'proj=longlat'
'ellps=WGS84'
'no_defs'
END
CLASS
NAME 'maps'
STYLE
SYMBOL "circle"
SIZE 7.0
OUTLINECOLOR 0 0 0
COLOR 170 211 227
END
END
END
END
Template.html --
<!-- MapServer Template -->
<tr><td>[lrn]</td><td>[NAME]</td><td>[LAT]</td><td>[LON]</td><td>[ELEVATION]</td><td>[QUADNAME]</td></tr>
header.html--
<font size+1><b>Layer: airports</b></font><p>
<table cellpadding=5 cellspacing=2 border=0>
<tr bgcolor=#CCCCCC><td bgcolor=#ffffff> </td><th>name</th><th>latitude</th><th>longitude</th><th>address</th><th>description</th></tr>
footer.html --
</table><p>
If any finds any fault with my code or anything that should be added to get feature info then please let me know.
Awaiting reply.
With Regards,
Neelima Emmani
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120410/6857a1d2/attachment-0001.html
