[mapserver-users] labels problem
Fernando Norte
fernando at globalgeo.com.br
Tue Apr 10 08:11:39 EDT 2012
Hi Karina,
I need more information about your mapfile and font file to help you, try
to paste the code here or use http://pastebin.com/.
Try check if had any error in the mapfile, you can view this error just
showing the map with mode=map or declare a error log file in the mapfile
with: CONFIG "MS_ERRORFILE" "/path/to/file.log"
Maybe you not specify the FONT, or another error in mapfile.
Att,
2012/4/10 Karina Guardado <kguardado at gmail.com>
> Hi,
> I'm having problems with labels on my mapfile, when I use the
> parameter TYPE TRUETYPE then I can't see the map but when I erase this
> line I can see the map but never see the labels. I have checked the
> path to the fonset file and it is ok, also I have verified the .ttf
> file corresponding to the font exist. Any idea about this problem, I'm
> using mapserver 5.6.5
> regards
> Karina Guardado
> El Salvador
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120410/a4f95cf3/attachment.html
