[mapserver-users] Trouble with spatialite layer
Sven Geggus lists at fuchsschwanzdomain.de
Thu Apr 19 17:06:20 EDT 2012
Hello,
I'm trying to render a spatialite layer.
The spatialite file itself seems to be correct, because it can be
viewed in qgis and can be dumped using ogrinfo:
$ogrinfo /home/sven/osm/topo/ocean.sqlite polygons -summary
INFO: Open of `ocean.sqlite'
      using driver `SQLite' successful.
Layer name: polygons
Geometry: Polygon
Feature Count: 31672
Extent: (-20037508.342789, -20037508.342789) - (20037508.342789, 20037508.342789)
Layer SRS WKT:
PROJCS["WGS 84 / Pseudo-Mercator",
    GEOGCS["WGS 84",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563,
                AUTHORITY["EPSG","7030"]],
            AUTHORITY["EPSG","6326"]],
        PRIMEM["Greenwich",0,
            AUTHORITY["EPSG","8901"]],
        UNIT["degree",0.0174532925199433,
            AUTHORITY["EPSG","9122"]],
        AUTHORITY["EPSG","4326"]],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    PROJECTION["Mercator_1SP"],
    PARAMETER["central_meridian",0],
    PARAMETER["scale_factor",1],
    PARAMETER["false_easting",0],
    PARAMETER["false_northing",0],
    EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext  +no_defs"],
    AUTHORITY["EPSG","3857"],
    AXIS["X",EAST],
    AXIS["Y",NORTH]]
FID Column = OGC_FID
Geometry Column = GEOMETRY
However this will not render in mapserver (6.0.1) using the following
layer syntax:
LAYER
   DEBUG 9
   MAXSCALEDENOM  2000000
   MINSCALEDENOM     5000
   NAME "meer"
   TYPE POLYGON
   CONNECTIONTYPE ogr
   CONNECTION "ocean.sqlite"
   DATA "select GEOMETRY from polygons"
   STATUS ON
   GROUP "default"
   CLASS
     NAME "ocean"
     STYLE
       COLOR "#579ae3"
     END
   END
END
Because of the debug level I get the following Error message on any single feature:
msOGRFileNextShape: Rejecting feature (shapeid = XXXXX, tileid=0) of incompatible type for this layer (feature wkbType 0, layer type 2)
Any hint?
Sven
"Ich fürchte mich nicht vor der Rückkehr der Faschisten in der Maske der
Faschisten, sondern vor der Rückkehr der Faschisten in der Maske der
Demokraten" (Theodor W. Adorno)
/me is giggls at ircnet, http://sven.gegg.us/ on the Web
