[mapserver-users] Re: pdf vector output in 6.02
thomas bonfort
thomas.bonfort at gmail.com
Mon Apr 23 03:25:38 EDT 2012
Can you provide a backtrace ?
thomas
On Mon, Apr 23, 2012 at 09:17, Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi> wrote:
> Hi,
> PDF output works for me on Windows (MS4W) but I seem to have problems with Linux and Mapserver 6.0.1 also. This one gives HTTP 500 Internal error message and on the server side there seems to occur a segfault
> http://188.64.1.61/cgi-bin/osm-mapserver_i?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=469&HEIGHT=354&LAYERS=default&TRANSPARENT=TRUE&FORMAT=application/x-pdf&BBOX=385063.18278820685,6671589.90189085,385461.47239845013,6671890.529869583&SRS=EPSG:3067&STYLES=
> Same with SVG output. Png etc. works fine. I have the same outputformat as you.
> -Jukka Rahkonen-
> frequens wrote:
>> Weird.To add a little:
>> With 5.6.5 I am able to get a vector pdf using mapserv or shp2img,
>> mapscript dies without message.
>> With 6.0.2 in all three cases (shp2img, mapserv, mapscript) the pdf
>> gets created, yet contains only the rendered raster image of the
>> vector layers.
>> Why this fallback to raster rendering, is this something supposed to
>> happen? All the underlying libraries are the same.
>> Any hints?
>> BR
>> frequens
>> On Fri, Apr 20, 2012 at 11:50 PM, frequens <frequens at gmail.com> wrote:
>> > Hi all,
>> > I am having trouble producing a high quality vector output pdf with
>> > 6.02 php mapscript (same trouble using shp2img)
>> > Cairo is enabled, the pdf file even gets created, but
>> contains only a
>> > raster image?
>> > Pdf output is enabled:
>> > IMAGETYPE PDF
>> > and
>> > OUTPUTFORMAT
>> > NAME "pdf"
>> > DRIVER CAIRO/PDF
>> > MIMETYPE "application/x-pdf"
>> > IMAGEMODE RGB
>> > EXTENSION "pdf"
>> > END
>> > Since the mapserver documentation on pdf creation is rather archaic,
>> > any help (a stripped version of someone's mapfile?) would be
>> > appreciated!
>> > My cairo library is rather old also: 1.4.10. Might this
>> have any influence?
>> > Many thanks in advance,
>> > frequens
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
