[mapserver-users] Fail to build Mapscript Python with current source
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Fri Apr 27 09:04:09 EDT 2012
I'm on a CentOS 6.2, x86_64 bit system:
/configure --with-gd --with-zlib --with-tiff --with-agg
--with-experimental-png --with-freetype=/usr/bin/freetype-config
--with-gdal=/usr/bin/gdal-config --with-ogr=/usr/bin/gdal-config
--with-geos=/usr/bin/geos-config --with-cairo=yes --with-proj --with-wfs
--with-wcs --with-sos --with-wmsclient --with-wfsclient --with-xpm
--with-postgis=/usr/bin/pg_config --with-mygis=/usr/bin/mysql_config
--with-curl-config=/usr/bin/curl-config
--with-xml2-config=/usr/bin/xml2-config --with-php=/usr/bin/php-config
--with-fribidi-config=/usr/lib64/pkgconfig/fribidi.pc
--with-fastcgi=/usr --without-pdf --without-eppl --with-threads
--enable-debug --disable-runpath
cd mapscript/python
swig -python -shadow -modern -o mapscript_wrap.c ../mapscript.i
cd ../..
make
cd mapscript/python
python setup.py build
The build fails with:
gcc -pthread -fno-strict-aliasing -O2 -g -pipe -Wall
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m64 -mtune=generic -D_GNU_SOURCE -fPIC
-fwrapv -DNDEBUG -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
-D_GNU_SOURCE -fPIC -fwrapv -fPIC -DUSE_FASTCGI=1 -DUSE_CAIRO=1
-DUSE_FRIBIDI=1 -DUSE_FRIBIDI2=1 -DUSE_WMS_LYR=1 -DUSE_WFS_LYR=1
-DUSE_SOS_SVR=1 -DUSE_LIBXML2=1 -DUSE_CURL=1 -DUSE_CURLOPT_PROXYAUTH=1
-DUSE_WCS_SVR=1 -DUSE_WFS_SVR=1 -DUSE_WMS_SVR=1 -DUSE_POSTGIS=1
-DPOSTGIS_HAS_SERVER_VERSION=1 -DUSE_GDAL=1 -DUSE_OGR=1 -DUSE_GEOS=1
-DUSE_THREAD=1 -DUSE_PROJ=1 -DUSE_GD=1 -DUSE_GD_GIF=1 -DUSE_GD_PNG=1
-DUSE_GD_JPEG=1 -DUSE_GD_WBMP=1 -DUSE_GD_FT=1 -DGD_HAS_FTEX_XSHOW=1
-DGD_HAS_GDIMAGEGIFPTR=1 -DGD_HAS_GETBITMAPFONTS=1
-DGD_HAS_GET_TRUE_COLOR_PIXEL=1 -DUSE_ICONV=1 -DUSE_JPEG=1 -DUSE_GIF=1
-DUSE_PNG=1 -DUSE_ZLIB=1 -DUSE_FREETYPE=1 -DHAVE_VSNPRINTF=1
-DNEED_STRLCPY=1 -DNEED_STRLCAT=1 -DNEED_STRRSTR=1 -DDISABLE_CVSID=1
-I../.. -I/usr/include/freetype2 -Irenderers/agg/include
-I/usr/include/gdal -I/usr/include -I/usr/include/fastcgi
-I/usr/include/libxml2 -I/usr/include/fribidi -I/usr/include/cairo
-I/usr/include/pixman-1 -I/usr/include/libpng12 -I/usr/include/python2.6
-I/home/rpmbuild/tmp/mapserver-6.1.20120426 -c pygdioctx/pygdioctx.c -o
build/temp.linux-x86_64-2.6/pygdioctx/pygdioctx.o
pygdioctx/pygdioctx.c: In function ‘PyFileIfaceObj_IOCtx_GetBuf’:
pygdioctx/pygdioctx.c:84: warning: passing argument 3 of
‘PyString_AsStringAndSize’ from incompatible pointer type
/usr/include/python2.6/stringobject.h:172: note: expected ‘Py_ssize_t *’
but argument is of type ‘int *’
gcc -pthread -shared build/temp.linux-x86_64-2.6/mapscript_wrap.o
build/temp.linux-x86_64-2.6/pygdioctx/pygdioctx.o -L../../ -L/usr/lib64
-L/usr/lib64 -L/usr/lib -L/usr/lib64
-L/home/rpmbuild/tmp/mapserver-6.1.20120426 -lpython2.6 -lmapserver
-lfreetype -lgd -ljpeg -lpng -lz -lXpm -lX11 -lproj -lgif -lgdal -lpq
-lcurl -lgeos_c -lpthread -lc -lfcgi -lxml2 -lm -lfribidi -lstdc++
-lfontconfig -lcairo -lpng12 -lmapserver -o
build/lib.linux-x86_64-2.6/_mapscript.so
/usr/bin/ld: cannot find -lmapserver
collect2: ld returned 1 exit status
error: command 'gcc' failed with exit status 1
Anyway, there is a file libmapserver.la in the source directory.
What is it, that I'm mising?
Thanks,
Peter
Peter Hopfgartner
web  : http://www.r3-gis.com
