[mapserver-users] Problem with "ANGLE FOLLOW"
Christy Nieman
cnieman at dmsolutions.ca
Mon Dec 3 06:35:59 PST 2012
ANGLE FOLLOW is subject to MAXOVERLAPANGLE (see
http://mapserver.org/mapfile/label.html). If there is an angle between
letters that is larger than 22.5 (if you don't have a manually-set
value), then the label will not be drawn.
I wrote a blog post that may help you understand:
http://research.dmsolutions.ca/2011/new-and-exciting-in-mapserver-6-0/
Christy
On 12/03/2012 09:07 AM, umn-ms at hydrotec.de wrote:
>> Try lowering the BUFFER number? ...
> Good idea. But even changing to "BUFFER 0" didn't change anything ...
> Problem is still there.
> Benedikt
> TC Haddad <tchaddad at gmail.com> schrieb am 03.12.2012 13:54:56:
>> 03.12.2012 13:55
>> An
>> "umn-ms at hydrotec.de" <umn-ms at hydrotec.de>
>> Kopie
>> Thema
>> Re: [mapserver-users] Problem with "ANGLE FOLLOW"
>> Try lowering the BUFFER number? If each label has a big buffer, then
>> less labels can fit...
>> Tanya
>> On Dec 3, 2012, at 2:56 AM, umn-ms at hydrotec.de wrote:
>>> Hi
>>> I'm using ANGLE-FOLLOW in Mapserver 6.2 to label lines.
>>> Unfortunately only 5 of 12 features are labeld.
>>> I attach an example with data and mapfile. It can be used with
>>> All features are drawn, but most of them are not labeld, although there
>>> should be enough space for all labels.
>>> (To activate this example, one has to add arialbd.ttf in the
>>> test-directory. I didn't attach this one, because of size-limits
>>> in this mailing-list...)
>>> Without "ANGLE FOLLOW" all labels are drawn.
>>> Benedikt
>>> #Layerdefinition:
>>> LAYER
>>> NAME "Striche"
>>> TYPE LINE
>>> STATUS ON
>>> DEBUG 5
>>> TEMPLATE "dummy.html"
>>> TOLERANCE 0
>>> DATA "Striche"
>>> LABELITEM "name"
>>> CLASS
>>> NAME "Hauptsammler"
>>> LABEL
>>> COLOR 0 0 0
>>> OUTLINECOLOR 255 255 255
>>> OUTLINEWIDTH 6
>>> TYPE truetype
>>> SIZE 5
>>> MINDISTANCE 0
>>> ANGLE FOLLOW
>>> FORCE TRUE
>>> FONT "arial-bold"
>>> BUFFER 10
>>> END
>>> STYLE
>>> OUTLINECOLOR 0 0 0
>>> WIDTH 3
>>> PATTERN 5 5 END
>>> LINECAP BUTT
>>> END
>>> END
>>> END
>>> (See attached file: missinglabel.zip)
>>> <missinglabel.zip>
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121203/d9ee7ff2/attachment.html>
