[mapserver-users] Problem with "ANGLE FOLLOW"
Havard Tveite
havard.tveite at umb.no
Mon Dec 3 07:33:23 PST 2012
I have updated the documentation for 6.2 by including
a reference to MAXOVERLAPANGLE in the description of
ANGLE FOLLOW.
Håvard
On 12/3/2012 3:35 PM, Olivier Courtin wrote:
> Hi,
> For same kind of need (i.e hydrologic line to label), i've found that:
> - Your lines must be long enough to allow the label to fit on (seems already your case, as it works for you without ANGLE FOLLOW)
> - You have to increase MAXOVERLAPANGLE property
> - Your lines have to be as smooth as possible
> Below a sample of such a thing with two layers, one with the data itself and one another using a generalization trought PostGIS ST_Simplify to help the geometry to be smoother enough
> LAYER
> NAME "label"
> METADATA
> "ows_title" "Label des cours d'eau Carthage AERMC"
> "ows_extent" "573401 6050407 1242369 6811885"
> "ows_featureid" "gid"
> END
> PROJECTION
> "init=epsg:2154"
> END
> TYPE line
> STATUS on
> DATA "geom from (SELECT gid, ST_simplify(geom, 200) As geom , toponyme, classe::integer
> FROM aermc.cours_eau WHERE toponyme IS NOT NULL)
> AS foo using unique gid using srid=2154"
> CONNECTIONTYPE postgis
> CONNECTION "host=XXXX port=5432 dbname=XXXX user=XXXX"
> LABELITEM toponyme
> CLASSITEM classe
> CLASS
> EXPRESSION ([classe] <= 2)
> LABEL
> COLOR 0 0 0
> OUTLINECOLOR 210 210 210
> TYPE TRUETYPE
> FONT vera
> SIZE 10
> ANTIALIAS TRUE
> POSITION UC
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE auto
> REPEATDISTANCE 500
> MAXOVERLAPANGLE 45
> END
> END
> CLASS
> EXPRESSION ([classe] <= 4)
> LABEL
> COLOR 30 30 30
> TYPE TRUETYPE
> FONT vera
> SIZE 8
> ANTIALIAS TRUE
> POSITION UC
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE auto
> MAXOVERLAPANGLE 40
> END
> END
> CLASS
> LABEL
> COLOR 60 60 60
> TYPE TRUETYPE
> FONT vera
> SIZE 8
> ANTIALIAS TRUE
> POSITION UC
> ANGLE FOLLOW
> PARTIALS FALSE
> MINFEATURESIZE auto
> MAXOVERLAPANGLE 40
> END
> END
> END
> LAYER
> NAME "cours_eau"
> METADATA
> "ows_title" "Cours d'eau Carthage"
> END
> PROJECTION
> "init=epsg:2154"
> END
> TYPE line
> STATUS on
> DATA "geom from (SELECT gid, geom , classe::integer FROM aermc.cours_eau
> CLASSITEM classe
> CLASS
> STYLE
> COLOR 33 33 210
> WIDTH 5
> END
> END
> CLASS
> STYLE
> COLOR 66 66 210
> WIDTH 3
> END
> END
> CLASS
> STYLE
> COLOR 99 99 210
> WIDTH 1
> END
> END
> END
> HTH,
> Olivier
