[mapserver-users] Help - debug error
Lin, Joyce Joyce.Lin at pxd.com
Fri Dec 7 15:44:52 PST 2012
Thank you! That fixed my issue.
From: Brent Fraser [mailto:bfraser at geoanalytic.com]
Sent: Friday, December 07, 2012 5:35 PM
To: Lin, Joyce
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Help - debug error
try putting your layer name in quotes
              LAYER
                     NAME '2013_PXD_Wells'
Best Regards,
Brent Fraser
On 12/7/2012 4:14 PM, Lin, Joyce wrote:
Hello,
Can somepone help me or explain me the error please:
getString(): Symbol definition error. Parsing error near (2013):(line 38)
and my mapfile is below
MAP
   CONFIG "MS_ERRORFILE" "/ms4w/tmp/ms_tmp/ms_error_well.txt"
   DEBUG 5
       SIZE 800 650
       STATUS ON
       EXTENT  2016274.741485 176555.010138 2688771.295454 620600.467750
       UNITS FEET
       INCLUDE "/ms4w/apps/geomoose2/maps/geomoose_globals.map"
              WEB
                     METADATA
                           'ows_title' '2013 Pioneer Drilling Program'
                           'ows_srs' 'EPSG:4267 EPSG:4326 EPSG:900913 EPSG:3857'
                           'ows_enable_request' '*'
                           'ows_onlineresource' 'http://www.pxd.com'
                     END
              END
              PROJECTION
                     'init=epsg:3857'
              END
              LEGEND
                       STATUS ON
                       LABEL
                           TYPE TRUETYPE
                           FONT vera_sans
                           SIZE 8
                           COLOR 0 0 0
                       END
              END
              LAYER
                     NAME 2013_PXD_Wells
                     DATA './2013_PXD_Wells.shp'
                     STATUS ON
                     TYPE LINE
                     LABELITEM 'Well_Name'
                     LABELCACHE ON
                     LABELMAXSCALE 20000
                     PROJECTION
                            'init=epsg:32040'
                     END
                           CLASS
                                  STYLE
                                  #      WIDTH 1
                                         COLOR 0 0 0
                                  #      MAXSCALEDENOM 50000
                                  END
                                  #STYLE
                                  #      SIZE 1
                                  #      COLOR -1 -1 -1
                                  #      OUTLINECOLOR 255 204 153
                                  #END
                                  LABEL
                                         TYPE TRUETYPE
                                         FONT vera_sans
                                         SIZE 8
                                         ANGLE FOLLOW
                                         OUTLINECOLOR 254 254 200
                                         BUFFER 4
                                         MINFEATURESIZE auto
                                         PARTIALS FALSE
                                  #      POSITION cc
                                  END
                           END
                           METADATA
                                  # drill-down identify service record.
                                  'identify_record'    'templates/identify.html'
                                  # query.php / "Search Lease" functionality.
                                  'itemquery'   'templates/search_result.html'
                                  'itemquery-filter'   '/.*[qstring].*/i'
                                  'qstring_validation_pattern' '.'
                                  # Feature reports are stored in the conf/feature_report directory.
                                  'feature_report' 'Lease.xml'
                            'select_record'      'templates/select_result.html'
                                  'select_header' 'templates/select_header.html'
                                  'popups' 'Welle_popup.html'
                           END
                END
END ## end Map
Statement of Confidentiality:
This message may contain information that is privileged or confidential. If you receive this transmission in error, please notify the sender by reply e-mail and delete the message and any attachments.
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121207/ed30957b/attachment-0001.html>
