[mapserver-users] Map inset, anyone tried this?
Basques, Bob (CI-StPaul) bob.basques at ci.stpaul.mn.us
Thu Dec 13 13:58:34 PST 2012
All,
Wild thought here . . .
I'm wondering about how to approach the need to add a map inset to a MapServer call.  I know I can make separate calls and stack some maps on top of each other, but I'm wondering now about using a TRANSFORM of coordinates to put a Map Inset window into a Mapserver call in some way?
One thought was to use a SQL call to PostGIS and transform things in some fashion that way.  Another might be a method for defining a window, and then adding in a MapServer parameter to use a MAPfile to populate it.  This might also lead to some capabilities with respect to making some interesting embedded Legends, since the populating aspect might be a simple URL to populate the defined window in the map.  With MapServer making the call, the window could even be treated as a label object and label collisions could be handled as well . . .  hmmm, remember, I did say " wild".  :c)
In the back of my mind (for some number of years now) I've wanted the capabilities to actually draw things via a MapServer call in some form.  A Map Inset window with a tail, similar to OpenLayers or Google Popups for example, would be the best description I can think of.
Anyone tried anything like this?  I can see this being interesting as a capability especially for doing spatial reports (Which I'm in the middle of designing right now  . . .)
Thanks
Bobb
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121213/235c4ab0/attachment-0001.html>
