[mapserver-users] JPEG and OVERSAMPLE_RATIO
Cédric MOULLET cedric.moullet at gmail.com
Tue Dec 18 12:04:44 PST 2012
Thanks to Thomas, the problem has been solved by removing an OFFSITE
parameter configuring the layer (http://mapserver.org/en/mapfile/layer.html).
With the following layer configuration:
PROCESSING "RESAMPLE=AVERAGE"
PROCESSING "OVERSAMPLE_RATIO=16"
the visual quality of the produced image is very good (for the PNG and JPEG
format).
Best regards,
Cédric
On Mon, Dec 17, 2012 at 5:11 PM, Cédric MOULLET <cedric.moullet at gmail.com>wrote:
> No, we tried with 80 and it doesn't change anything.
> On Mon, Dec 17, 2012 at 5:00 PM, thomas bonfort <thomas.bonfort at gmail.com>wrote:
>> On Mon, Dec 17, 2012 at 4:49 PM, Cédric MOULLET <cedric.moullet at gmail.com
>> > wrote:
>>> Hi,
>>> Output formats:
>>> OUTPUTFORMAT
>>>   NAME "png"
>>>   MIMETYPE "image/png"
>>>   DRIVER "AGG/PNG"
>>>   EXTENSION "png"
>>>   IMAGEMODE "RGBA"
>>>   TRANSPARENT TRUE
>>>   FORMATOPTION "INTERLACE=OFF"
>>> END
>>> OUTPUTFORMAT
>>>   NAME jpeg
>>>   DRIVER "AGG/JPEG"
>>>   MIMETYPE "image/jpeg"
>>>   IMAGEMODE RGB
>>>   FORMATOPTION QUALITY=100
>> does changing this to values between 80 and 99 change something ?
>>>   EXTENSION "jpg"
>>> END
>>> URL's:
>>> 1.
>>> https://picasaweb.google.com/lh/photo/j_OClw5fGOeQE7K1wiimytMTjNZETYmyPJy0liipFm0?feat=directlink
>>> 2.
>>> https://picasaweb.google.com/lh/photo/3q52h52EwOp9JzZm3KAWbNMTjNZETYmyPJy0liipFm0?feat=directlink
>>> 3.
>>> https://picasaweb.google.com/lh/photo/GTAThw7AOVMK-j-7DWAabtMTjNZETYmyPJy0liipFm0?feat=directlink
>>> Thanks in advance for your help !
>>> Cédric
>>> On Mon, Dec 17, 2012 at 4:24 PM, thomas bonfort <
>>> thomas.bonfort at gmail.com> wrote:
>>>> Can you post the outputformats defined in your mapfile, and the urls
>>>> used to access each of these images?
>>>> thomas
>>>> On Mon, Dec 17, 2012 at 4:18 PM, Cédric MOULLET <
>>>> cedric.moullet at gmail.com> wrote:
>>>>> I realize that links have been sent and not pictures
>>>>> Here are reachable links for the three cases:
>>>>> 1.
>>>>> 2.
>>>>> 3.
>>>>> Cédric
>>>>> On Mon, Dec 17, 2012 at 4:11 PM, Cédric MOULLET <
>>>>>> Hi,
>>>>>> The following issue has been observed with MapServer 6.0.3:
>>>>>> 1. Very good quality for a PNG with RESAMPLE=BILINEAR and
>>>>>> OVERSAMPLE_RATIO=16:
>>>>>> [image:
>>>>>> http://wms-bgdi.bgdi.admin.ch/?lang=xx&LAYERS=ch.swisstopo.pixelkarte-grau-pk100_bazl&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A21781&BBOX=513184,143152,519840,149808&WIDTH=256&HEIGHT=256]
>>>>>> 2. Less good quality for a PNG or JPEG with default resampling
>>>>>> settings:
>>>>>> [image:
>>>>>> http://wms-bgdi.bgdi.admin.ch/?lang=xx&LAYERS=ch.swisstopo.pixelkarte-grau-pk100_original&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A21781&BBOX=513184,143152,519840,149808&WIDTH=256&HEIGHT=256]
>>>>>> 3. Awful quality for JPEG with RESAMPLE=BILINEAR and
>>>>>> [image:
>>>>>> http://wms-bgdi.bgdi.admin.ch/?lang=xx&LAYERS=ch.swisstopo.pixelkarte-grau-pk100_bazl&FORMAT=image%2Fjpeg&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&SRS=EPSG%3A21781&BBOX=513184,143152,519840,149808&WIDTH=256&HEIGHT=256]
>>>>>> Any idea why the OVERSAMPLE_RATIO affects heavily the quality of JPEG
>>>>>> images ?
>>>>>> Thanks in advance for your help,
>>>>>> Cédric
>>>>> Political blog: http://cedricmoullet.blogspot.com/
>>>>> Welcome to my world: http://www.cedricmoullet.com/
>>>>> My Linked In profile: http://www.linkedin.com/in/cedricmoullet
>>>>> Twitter: http://twitter.com/cedricmoullet
>>>>> Home sweet home:
>>>>> http://map.geo.admin.ch/?crosshair=bowl&zoom=11&X=185241.24219&Y=561288.90625&bgOpacity=0&selectedNode=node_ch.swisstopo.fixpunkte-lage1
>>>>> _______________________________________________
>>>>> mapserver-users mailing list
>>>>> mapserver-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> Home sweet home:
> Home sweet home:
Home sweet home:
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20121218/2c7a69db/attachment.html>
