[mapserver-users] WFS Server - GetCapabilities : Wrong WGS84BoundingBox
Martin Kofahl
M.Kofahl at gmx.net
Wed Dec 19 14:05:23 PST 2012
Ludovic, can you please check the BBOX you said to be correct?
According to your mail EPSG:27562 BBOX 856234 15002 977228 165832 should be transformed to WGS84 5.59081 45.0235 7.27355 46.4437. What about 5.59118 45.0322 7.2442 46.4436? This is what ogr2ogr tells me. In case you can confirm this bbox I'll update the patch which will then probably go into next 6.2 release.
Kind regards,
Martin
-------- Original-Nachricht --------
> Datum: Tue, 16 Oct 2012 09:13:03 -0700 (PDT)
> Von: Ludovic Gnemmi <lgnemmi at rgd73-74.fr>
> An: mapserver-users at lists.osgeo.org
> Betreff: [mapserver-users] WFS Server - GetCapabilities : Wrong WGS84BoundingBox
> Hi List,
> And i'm a bit lost with my server :
> For each layer : The WGS84BoundingBox returned by WFS Capabilities is
> different from EX_GeographicBoundingBox returned by the WMS Capabilities
> (which is correct). Longitudes are slightly offset. And I don't undestand
> why. I'm runing MS 6.2rc1 (with gdal 1.9.2)
> Thanks for your help
> *WFS Capabilities for my layer*:
> <FeatureType><Name>commune</Name>
> <Title>commune</Title>
> <DefaultSRS>urn:ogc:def:crs:EPSG::27562</DefaultSRS>
> <OutputFormats><Format>text/xml; subtype=gml/3.1.1</Format>
> </OutputFormats><ows:WGS84BoundingBox dimensions="2">
> <ows:LowerCorner>*3.25449830506514*
> 45.0322364698095</ows:LowerCorner><ows:UpperCorner>*4.90746655965819*
> 46.4436690375305</ows:UpperCorner></ows:WGS84BoundingBox>
> *WMS Capabilities for the same layer: *
> <Layer queryable="0" opaque="0" cascaded="0">
> <CRS>EPSG:27562</CRS>
> <EX_GeographicBoundingBox>
> <westBoundLongitude>*5.59081*</westBoundLongitude>
> <eastBoundLongitude>*7.27355*</eastBoundLongitude>
> <southBoundLatitude>45.0235</southBoundLatitude>
> <northBoundLatitude>46.4437</northBoundLatitude>
> </EX_GeographicBoundingBox>
> <BoundingBox CRS="EPSG:27562" minx="856240" miny="14163" maxx="979490"
> maxy="165840"/><ows:LowerCorner>3.25449830506514
> <ows:UpperCorner>4.90746655965819
> 46.4436690375305</ows:UpperCorner></ows:WGS84BoundingBox></FeatureType>
> *And my map file :*
> map
> name "mymap"
> extent 856234 15002 977228 165832
> units meters
> projection
> "init=epsg:27562"
> end
> web
> metadata
> "wms_title" "Test WMS"
> "wms_srs" "EPSG:27562"
> "wfs_title" "Test WFS"
> "wfs_onlineresource" "http://..//mapfiles/mymap.map"
> "wfs_maxfeatures" "10000"
> "ows_enable_request" "*"
> END
> end
> LAYER
> CONNECTIONTYPE oraclespatial
> CONNECTION "usr/pwd at 192.168.10.18:1521/ora10"
> DATA "GEOM FROM usr.COMMUNE_PS USING UNIQUE UNIQUE_ID"
> NAME "commune"
> DUMP TRUE
> projection
> "init=epsg:27562"
> end
> METADATA
> "wms_title" "commune"
> "wms_extent" "856234 15002 977228 165832"
> "wfs_extent" "856234 15002 977228 165832"
> "wfs_title" "commune"
> "ows_srs" "EPSG:27562"
> "gml_include_items" "all"
> "gml_featureid" "UNIQUE_ID"
> END
> TYPE polygon
> OPACITY 100
> SIZEUNITS pixels
> LABELITEM "NOM"
> CLASS
> NAME "Untitled class"
> STYLE
> OPACITY 100
> OUTLINECOLOR 21 21 21
> WIDTH 1
> END
> END
> END
> http://osgeo-org.1560.n6.nabble.com/WFS-Server-GetCapabilities-Wrong-WGS84BoundingBox-tp5009072.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
