[mapserver-users] Multi-line labels
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Feb 2 10:16:08 EST 2012
Layers are rendered from bottom to top and I believe that now your centroide_pts are just there under the polygons.
By the way, STATUS OFF should mean that the layer is not at all in use. It is a bit odd that your layers still render, or at least the polygons.
-Jukka Rahkonen-
________________________________________
maddqc wrote:
> Hi all,
> I've have a problem with a mapfile that I need to show a particular label
with multi-line from my centroide_pts layer. But it doesn't work.
> When I use the map mode in a browser, there is only the layer unite_eval,
but my centroide layer is not showed.
> What's happening here? What can I do?
Thx
MAP
IMAGETYPE PNG
EXTENT 196198.810957 5012701.634582 198121.561850 5013781.503783
SIZE 1000 1000
UNITS meters
SHAPEPATH "/opt/mapping/maps/"
IMAGECOLOR 255 255 255
LAYER
NAME 'centroide_pts'
DATA './44071/centroide_pts.shp'
STATUS OFF
TYPE POINT
LABELITEM 'IDENT'
CLASS
STYLE
SIZE 7.0
COLOR 0 0 0
END
LABEL
SIZE 12
COLOR 0 0 0
ANGLE 0
POSITION lc
FORCE true
ANTIALIAS true
PARTIALS true
END
END
END
LAYER
NAME 'unite_eval'
DATA './44071/unite_eval.shp'
STATUS OFF
TYPE POLYGON
CLASS
NAME 'unite_eval'
STYLE
WIDTH 0.91
OUTLINECOLOR 0 0 0
COLOR 152 64 149
END
END
END
END
View this message in context: http://osgeo-org.1560.n6.nabble.com/Multi-line-labels-tp4359187p4359187.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
mapserver-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapserver-users
