[mapserver-users] How to label only largest displayed areas?
Anzel, Phil - NRCS, Fort Collins, CO Phil.Anzel at ftc.usda.gov
Thu Feb 2 14:43:21 EST 2012
Hi, All,
How can I label only the largest displayed areas within an extent? For example, if I'm labeling states of the United States and my extent covers a small region around the Maine, New Hampshire and Massachusetts junction, I only want a single label for each state, chosen by the largest displayed area (within the current map extent) in each state.
I'm using spatial data stored in Microsoft's SQL Server 2008.
I've created an enhancement request ticket (#4173: Define a current layer extent's WKT string for use in Data statement) as one possible approach, but this approach requires a change to MapServer.
Is there a better way?
- Phil Anzel
  Vistronix Inc for USDA/NRCS/ITC
This electronic message contains information generated by the USDA solely for the intended recipients.  Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties.  If you believe you have received this message in error, please notify the sender and delete the email immediately.
