[mapserver-users] RE: How to label only largest displayed areas?
Anzel, Phil - NRCS, Fort Collins, CO Phil.Anzel at ftc.usda.gov
Fri Feb 3 09:24:16 EST 2012
Steve W,
Thanks for the MINDISTANCE suggestion; I'll give that a go to get part way there, along with to Steve L.'s suggestion to sort. Still not quite at the goal yet.
- Phil
-----Original Message-----
Sent: Friday, February 03, 2012 7:00 AM
To: mapserver-users at lists.osgeo.org; Anzel, Phil - NRCS, Fort Collins, CO
Subject: RE: How to label only largest displayed areas?
Hi, Jukka and Steve,
Thanks for your replies. Jukka is correct, I do not believe it is simple. Steve, your approach sorts all areas and then filters by those visible in the layer's extent. I'm looking for ranking by the clipped area. For example, if the current map and layer's extent shows the a small sliver of the mainland of California and a larger visible part of an island that is part of California, only the island would be labeled, as its visible area is larger than that of the sliver.
- Phil
From: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Sent: Thursday, February 02, 2012 4:01 PM
To: Lime, Steve D (DNR); Anzel, Phil - NRCS, Fort Collins, CO; mapserver-users at lists.osgeo.org
Subject: Re: How to label only largest displayed areas?
I understood that meaning was to put exactly one label per state. Each state, even tiny ones, should be labeled. But one state should get only one label even if the map window is splitting the state polygon into two or more intersections. Those intersections may be bigger than the tiny state. Not extremely simple.
-Jukka-
________________________________________
L Lime, Steve D (DNR) wrote:
> I'd do this by sorting features based on area (ascending order). This would draw the smallest polygons first, but would put the labels for the shapes with the largest area into the label cache last (where they would be placed and drawn first). I've done this with labeling lakes and it works fine.
Steve
Date: Thu, 02 Feb 2012 15:19:19 -0500
From: Stephen Woodbridge <woodbri at swoodbridge.com>
Subject: Re: [mapserver-users] How to label only largest displayed areas?
Message-ID: <4F2AEFC7.5020704 at swoodbridge.com>
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Hi Phil,
I'm not sure I understand what you need here. Mapserver currently
displays one label per polygon based on the visible extents of that
polygon. If your state is represented by a single record with a
multipolygon like the state and its coastal islands, then I suspect that
it will label the first polygon in the multipolygon object. In the cases
where you have multiple records in your dataset one for the state and
additional polygons for the islands, then all of these are added to the
labelcache and the last one in the labelcache is labeled first if the
label does not collide. So in this case you could sort your data by
state and area increasing in size so you largest is loaded last and
labeled first.
You can also control the number of labels using MINDISTANCE <dist> so
the same label in a layer is not presented within <dist> units of
another with the same name.
Do you need more than this?
Are you trying to place the label in the biggest open space? (this we
can not do because there is no easy algorithm for this).
-Steve W
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Anzel, Phil - NRCS, Fort Collins, CO
Sent: Thursday, February 02, 2012 1:43 PM
Cc: Anzel, Phil - NRCS, Fort Collins, CO
Subject: [mapserver-users] How to label only largest displayed areas?
Hi, All,
How can I label only the largest displayed areas within an extent? For example, if I'm labeling states of the United States and my extent covers a small region around the Maine, New Hampshire and Massachusetts junction, I only want a single label for each state, chosen by the largest displayed area (within the current map extent) in each state.
I'm using spatial data stored in Microsoft's SQL Server 2008.
I've created an enhancement request ticket (#4173: Define a current layer extent's WKT string for use in Data statement) as one possible approach, but this approach requires a change to MapServer.
Is there a better way?
Thanks.
- Phil Anzel
  Vistronix Inc for USDA/NRCS/ITC
This electronic message contains information generated by the USDA solely for the intended recipients.  Any unauthorized interception of this message or the use or disclosure of the information it contains may violate the law and subject the violator to civil or criminal penalties.  If you believe you have received this message in error, please notify the sender and delete the email immediately.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
