[mapserver-users] Mapfile Generators
pcreso at pcreso.com pcreso at pcreso.com
Fri Feb 3 14:58:02 EST 2012
Hi Paul,
QGIS has such a tool, I'm not sure about Arc.
You should be able to handcraft a generic mapfile as a template you can re-use as required. I had a use case some time ago for this sort of thing & used a Linux shell script to make the text substitutions in such a template from reading a spreadsheet containing the mapfile parameters required for each individual shapefile.
These days I tend to manage data in Postgis, & use a filter or mapserver's variable substitution to manage such situations.
Using a single mapfile with cgi wrappers to re-use it in this way for different datasets works better for me than maintaining lots of separate mapfiles.
In a couple of situations where this is not flexible enough, having a cgi actually contain the mapfile text, so it writes the customised mapfile, then invokes it, also works for me.
Cheers,
   Brent Wood
--- On Sat, 2/4/12, Paul Maddock <Paul.Maddock at ijus.net> wrote:
Subject: [mapserver-users] Mapfile Generators
To: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
Date: Saturday, February 4, 2012, 2:49 AM
Hi all,  Are there any extensions of ArcView 10 which I can export .shp files into mapfiles or possibly any other open source mapfile generators?  It seems time consuming to manually create these map files if I have a large collection of shapefiles.   Many thanks,Paul
-----Inline Attachment Follows-----
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120203/1b39fca5/attachment.html
