[mapserver-users] MapServer SOS Configuration
Ebrahim Poorazizi ebrahim.poorazizi at gmail.com
Tue Feb 7 16:56:52 EST 2012
I tried to set up MapServer SOS but I faced a problem: the SOS doesn't
return anything. You may see the map file I have created below:
    MAP
      NAME "SOS_DEMO"
      STATUS ON
      SIZE 400 300
      EXTENT -180 -90 180 90
      UNITS METERS
      SHAPEPATH "C:\ms4w\apps\tutorial\data"
      IMAGECOLOR 255 255 255
      WEB
        IMAGEPATH "C:\ms4w\apps\tutorial\templates"
        IMAGEURL "C:\ms4w\apps\tutorial\images"
        METADATA
          "sos_onlineresource" "
http://127.0.0.1:8282/cgi-bin/mapserv.exe?map=c:/ms4w/mysos.map?"
          "sos_title"          "My SOS Demo Server"
          "sos_srs"            "EPSG:4326"
          "sos_enable_request" "*"
        END
      END
      PROJECTION
        "init=epsg:4326"
      END
      LAYER
        NAME "sos_point"
        METADATA
          "sos_procedure"  "ifgi-sensor-1"
          "sos_offering_id" "WQ1289"
          "sos_observedproperty_id" "Water Quality"
          "sos_describesensor_url" "http://127.0.0.1:8181/DescribeSensor.xml"
        END
        TYPE POINT
        STATUS ON
        DATA 'sospoint'
        PROJECTION
          "init=epsg:4326"
        END
        CLASS
          NAME 'sospoint'
          STYLE
            COLOR 255 128 128
          END
        END
      END
    END
As you see, I tried to retrieve sensor data from a shapefile. The message
returned by the SOS is:
<om:ObservationCollection xmlns:gml="http://www.opengis.net/gml" xmlns:ows="
http://www.opengis.net/ows/1.1" xmlns:swe="http://www.opengis.net/swe/1.0.1"
 xmlns:xlink="http://www.w3.org/1999/xlink"xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xmlns:sos="
http://www.opengis.net/sos/1.0" xmlns:ms="
http://mapserver.gis.umn.edu/mapserver" xmlns:om="
http://www.opengis.net/om/1.0" gml:id="WQ1289"xsi:schemaLocation="
http://www.opengis.net/om/1.0 http://schemas.opengis.net/om/1.0.0/om.xsd
http://127.0.0.1:8282/cgi-bin/mapserv.exe?map=c:/ms4w/mysos.map?service=WFS&version=1.1.0&request=DescribeFeatureType&typename=urban
<om:member>
<om:Observation>
<om:procedure xlink:href="urn:ogc:def:procedure:ifgi-sensor-1"/>
<om:observedProperty>
<swe:CompositePhenomenon gml:id="Water Quality" dimension="3">
<swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:Id"/>
<swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:sensor_nam"/>
<swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:sensor_val"/>
</swe:CompositePhenomenon>
</om:observedProperty>
<om:resultDefinition>
<swe:DataBlockDefinition>
<swe:components>
<swe:DataRecord/>
</swe:components>
<swe:encoding>
<swe:TextBlock tokenSeparator="," blockSeparator=" " decimalSeparator="."/>
</swe:encoding>
</swe:DataBlockDefinition>
</om:resultDefinition>
<om:result></om:result>
</om:Observation>
</om:member>
</om:ObservationCollection>
Although I put 6 observations into the shapefile but the SOS doesn't return
any. Would you please let me know what I should do to resolve the problem?!
Regards,
Ebrahim
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120207/d347fce2/attachment-0001.html
