[mapserver-users] RE: using pattern or nullformat in templates - Mapserver 5.4
Mark Volz MarkVolz at co.lyon.mn.us
Wed Feb 8 15:29:43 EST 2012
Hello,
I may have answered my own question.  The following line works, however it has a mismatched number of brackets so it could be better written.
 [item name="PHYZIP" nullformat="No Site Address" pattern=/^[1-9]
How would I rewrite this line of the template so that it is clean?
Thank You
Mark Volz
GIS Specialist
_____________________________________________
Sent: Wednesday, February 08, 2012 2:17 PM
To: 'mapserver-users at lists.osgeo.org'
Subject: using pattern or nullformat in templates - Mapserver 5.4
Hello,
I am trying to display an address as part of my identify parcel template.  The template works fine for parcels that have a valid address.  However, for parcels that do not have an address a "0" is displayed (the zip field is a integer).  How can I change the results so that either nothing, or a message such as "no site address" is displayed?
When I try to use pattern:
*       [item name="PHYZIP" pattern=/^[1-9]/]   - displays the address if there is one, or "1/]" is there is not an address.
*       [item name="PHYZIP" pattern="/^[1-9]/"]  - crashes
Nullformat appears to only work with strings that are null, not integers that are 0.  Is there a way to set a nullvalue, for example:
*       [item name="PHYZIP" nullformat="No Physical Address" nullvalue="0"]
Thanks
Mark Volz
GIS Specialist
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120208/dc38ff0b/attachment.html
