[mapserver-users] replacing layer with different scales.
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Thu Feb 9 07:09:33 EST 2012
Name the real layers as MIPARE_A_CLOSE and MIPARE_A_FAR and then make requests with the grouping layer name &layers=MIPARE and it should start to work.
-Jukka Rahkonen-
ElPer wrote:
> Hello
> I need help with the mapfile of the mapserver and I hope you
> can help me.
> I want to replace one layer with another at different scale, but I get
> always an Error.
> In the documentation I read that I can replace it with the same name
> according to different scales:
> "The name should be unique, unless one layer replaces another
> at different
> scales."
> Our Mapserver uses also Tilecache and I'm not sure if the
> error comes from
> the mapserver or tilecache.
> Thanks for your help
> Here is my mapfile:
> MAP
> NAME Nautical Map
> STATUS ON
> # Spherical Mercator
> EXTENT -20037508.34 -20037508.34 20037508.34 20037508.34
> PROJECTION
> "init=epsg:900913"
> END
> SIZE 2048 2048
> IMAGETYPE mypng
> OUTPUTFORMAT
> NAME "mypng"
> DRIVER AGG/PNG
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> TRANSPARENT ON
> FORMATOPTION "INTERLACE=OFF"
> END
> WEB
> IMAGEPATH "/opt/fgs2/tmp/ms_tmp/"
> IMAGEURL "/ms_tmp/"
> METADATA
> "wms_srs" "EPSG:4326 EPSG:900913"
> END
> END
> LAYER
> NAME MIPARE_A_1
> GROUP "MIPARE"
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> TYPE POLYGON
> DATA
> "data/Scale_S57_Shapefile/25000/DE416020/MIPARE/A/MIPARE.shp"
> PROCESSING "CLOSE_CONNECTION=DEFER"
> PROCESSING "LABEL_NO_CLIP=ON"
> MINSCALEDENOM 0
> MAXSCALEDENOM 24999
> CLASS
> EXPRESSION ([CATMPA] == 2)
> STYLE
> SIZE 10
> OUTLINECOLOR 200 0 255
> SYMBOL mipare_torea
> END
> END
> CLASS
> EXPRESSION (([CATMPA] == 3) || ([CATMPA] == 4))
> STYLE
> SIZE 10
> SYMBOL mipare_subea
> END
> END
> CLASS
> STYLE
> SIZE 1
> SYMBOL dashed_line
> END
> END
> END
> LAYER
> NAME MIPARE_A_1
> GROUP "MIPARE"
> STATUS ON
> PROJECTION
> "init=epsg:4326"
> END
> TYPE POLYGON
> DATA
> "data/Scale_S57_Shapefile/45000/DE316001/MIPARE/A/MIPARE.shp"
> MINSCALEDENOM 25000
> MAXSCALEDENOM 499999
> CLASS
> STYLE
> SIZE 10
> SYMBOL mipare_torea
> END
> END
> CLASS
> STYLE
> SIZE 10
> SYMBOL mipare_subea
> END
> END
> CLASS
> STYLE
> SIZE 1
> SYMBOL dashed_line
> END
> END
> END
> END
> And here is the Exception wich I get:
> Mapserver message:
> Did not get image data back.
> URL:
> http://127.0.0.1:8181/cgi-bin/mapserv?MAP=/opt/fgs2/www/htdocs
/nautical.map&transparent=true&layers=MIPARE_A_1> &styles=&service=WMS&width=612&format=image%2Fpng&request=GetM
ap&height=612&srs=EPSG%3A900913&version=1.1.1&bbox=1104629.71327%> 2C7248943.79384%2C1116324.57859%2C7260638.65917
> Content-Type Header: application/vnd.ogc.se_xml
> Response:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> <!DOCTYPE ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1">
> <ServiceException code="LayerNotDefined">
> msWMSLoadGetMapParams(): WMS server error. Invalid layer(s)
> given in the
> LAYERS parameter.
> </ServiceException>
> </ServiceExceptionReport>
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Service.py", line 323,
> in cgiHandler
> format, image = service.dispatchRequest( params,
> path_info, req_method,
> host )
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Service.py", line 226,
> in dispatchRequest
> (format, data) = self.renderTile(t, params.has_key('FORCE'))
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Service.py", line 138,
> in renderTile
> data = layer.render(tile, force=force)
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Layer.py", line 435,
> in render
> image = self.renderMetaTile(metatile, tile)
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Layer.py", line 395,
> in renderMetaTile
> data = self.renderTile(metatile)
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Layers/WMS.py", line
> 29, in renderTile
> tile.data, response = wms.fetch()
> File
> "/opt/fgs2/www/htdocs/tilecache-2.10/TileCache/Client.py", line 68,
> in fetch
> raise Exception("Did not get image data back. \nURL:
> %s\nContent-Type
> Header: %s\nResponse: \n%s" % (self.url(), ctype, data))
> http://osgeo-org.1560.n6.nabble.com/replacing-layer-with-diffe
rent-scales-tp4378365p4378365.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
