[mapserver-users] Release of MapServer 6.0.2 and 5.6.8
Alan Boudreault aboudreault at mapgears.com
Thu Feb 9 11:30:02 EST 2012
Direct link to UbuntuGIS packages:
https://launchpad.net/~ubuntugis/+archive/ubuntugis-unstable/+packages
Alan
On 12-02-09 11:22 AM, Alan Boudreault wrote:
> MapServer 6.0.2 is now in the UbuntuGIS unstable PPA for Hardy, Lucid,
> Natty and Oneiric.
> Alan
> On 12-02-08 04:12 PM, Daniel Morissette wrote:
>> The MapServer team announces the release of MapServer versions 6.0.2 and
>> 5.6.8.
>> No new functionality has been added. 6.0.2 is a maintenance release that
>> fixes a few issues found since 6.0.1 including a recently discovered
>> security vulnerability in the handling of WFS filters inside a SLD. The
>> list of fixes since 6.0.1 is included at the end of this message.
>> Versions 5.6.8 includes fixes for the same WFS Filter security
>> vulnerability plus a few bug fixes that were backported since the last
>> official release. See the 5.6.8 HISTORY.TXT file for additional
>> information.
>> Source and binary downloads:
>> The source code is available at:
>> http://mapserver.org/download.html
>> The binary distributions listed in the download page should be updated
>> shortly with binaries for the new 6.0.2 release (and in some cases
>> 5.6.8).
>> The MapServer Team
>> Version 6.0.2 (2012-02-08):
>> - Fix security issue with quote escape in WFS GetFeature Filter (#4087)
>> - Fixed lexer buffer size issue with single quotes in a string (#4175)
>> - Raster layer fails to be drawn if the window is less than half a pixel
>> (#4172)
>> - Fixed SLD with FILTER doesn't apply properly to database layers (#4112)
>> - Fixed a problem with calls to labelInImage() (maplabel.c) when label
>> gutter
>> and label buffers are both used (#3303). Also changed the usage around
>> that
>> function to make it easier to understand. At a result the
>> "labelcache_map_edge_buffer" processing option (i.e. gutter) can be
>> provided
>> as a positive or negative value. (closes #1355 too)
>> - Added label->style markers to collision detection (#4133)
>> - Fixed single pixel coverages in WCS 2.0 (#4110)
>> - Fixed subsetting in WCS 2.0 (#4099)
>> - Fixed segfault when calling classObj::updateFromString() with SYMBOL
>> (#4062)
>> - fix rendering offset on thick GD lines (#3962)
>> - fix segfault on join with postgresql tables (#4074)
>> - Fixed Python Mapscript does not write COLOR to reference map (#4042)
>> - Fixed cannot add a style to a label in PHP/SWIG Mapscript (#4038)
>> - Add missing outputFormat support in WFS GetFeature POST XML requests
>> (#4052)
>> - Fixed schema validity issue for WCS 1.1 GetCoverage responses (#4047)
>> - fix centroid geomtransform parser (#4029)
>> - PHP MapScript is missing many styleObj properties (#3901)
>> - Added GEOMTRANSFORM in writeStyle function
>> - WCS 1.0: Fix crash with some _rangeset_axes values (#4020)
>> - Changed msDrawVectorLayer() not to cache shapes if attribute binding is
>> present after the first style (#3976)
>> - Fix mapscript to build when TRUE macro is not defined (#3926)
>> - Fix mapscript php build issues with MSVC (#4004)
>> - PHP/Mapscript: Segmentation fault when getting complex object using
>> PHP 5.2 (#3930)
>> - Fixed contains operator in logical expresions (#3974)
>> - Fix incorrect rendering of GD lines between 1 and 2 pixels wide (#3962)
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Alan Boudreault
http://www.mapgears.com/
