[mapserver-users] Mapserver + PostGIS ==> Blank Screen
cheryl buckley
cheryl.bckl at gmail.com
Sun Feb 12 11:43:36 EST 2012
I'm trying to get Mapserver connected with PostGIS. PostGIS is holding
a shape2pgsql contourline import in the table "atest" while a test has
the following columns (shape2pgsql default):
| Actions | gid | id | height | geom |
Quantum GIS picks the conection up perfectly to atest but with
Mapserver I just get a blank screen - or the color of IMAGECOLOR [. .
.] definition in test-2.map definitions.
Somehow it seems like I got the connection between Mapserver and
PostGIS running - at least the debug.log doesn't complain. But still
I'm not seeing any of my contour lines as I'm used to by Quantum GIS
Could someone give me a hint of what I'm missing out or where my mistake is?
I got the feeling that it is either has something to do with the DATA
property or the projection properties …
The Link with which I call the mapserv binary is:
http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map
But then it complains:
msDrawMap(): Image handling error. Unable to initialize image.
msPrepareImage(): General error message. Image dimensions not
specified. msCalculateScale(): General error message. Invalid image
width or height.
So I changed it to the following:
http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800
which results in no errors but therefore in a blank screen with a
clean debug.log ...
Even this one wont change anything:
http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map&mode=map&mapsize=600+800&layer=Contour
. . . my test-2.map definition is below:
P.S.: TEMPLATE "./Maps/test.map" does exist and is read and writeable
to the user which runs the webserver (Apache => User: www)
CONFIG "PROJ_LIB" "/usr/local/share/proj/" should also be valid:
FreeBSD [~]# ls /usr/local/share/proj
FL WO hawaii null stlrnc
GL27 alaska nad.lst nzgd2kgrid0005.gsb stpaul
IGNF conus nad27 other.extra world
MD epsg nad83 proj_def.dat
TN esri ntf_r93.gsb prvi
WI esri.extra ntv1_can.dat stgeorge
# =================================== test-2.map
MAP
CONFIG "MS_ERRORFILE" "./debug.log"
DEBUG 5
IMAGECOLOR 100 100 100
NAME "Contour"
EXTENT -90 -180 90 180
STATUS ON
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
WMS_NAME "Contour"
WMS_TITLE "SRTM - ContourLines"
WMS_ABSTRACT "My First Web Map Server"
WMS_SERVER_VERSION "1.1.1"
WMS_SRS "EPSG:4326"
WMS_ONLINERESOURCE
"http://192.168.10.15/cgi-bin/mapserv?map=./Maps/test.map"
WMS_ATTRIBUTION_TITLE "Some Attribute Title"
WMS_ATTRIBUTION_ONLINERESOURCE "http://www.myHomepage.com/"
WMS_KEYWORDLIST
"DEM,SRTM,Contourlines,Contour,Lines,Digital,Area,Model"
WMS_FEATURE_INFO_MIME_TYPE "text/html"
WMS_CONTACTELECTRONICMAILADDRESS "User at Domain.tld"
WMS_CONTACTPERSON "Some Reference Person"
WMS_CONTACTVOICETELEPHONE "+49-phoneNumber"
WMS_CONTACTORGANIZATION "Private"
WMS_ENCODING "utf-8"
END
END
LAYER # query layer from PostgreSQL table
NAME "Contour"
EXTENT 143 -20 145 -19
TYPE LINE
STATUS ON
DEBUG ON
DUMP true
METADATA
WMS_NAME "Contour"
WMS_TITLE "Contour Lines - 90m"
WMS_ABSTRACT "Contour Lines - 90m"
WMS_SRS "EPSG:4326"
GML_INCLUDE_ITEMS "all"
END
CONNECTIONTYPE POSTGIS
CONNECTION "host=192.168.10.15 port=5432
dbname=my_spatial_db user=admin password=******"
DATA "geom FROM atest using unique gid using srid=4326"
CLASS
STYLE
COLOR 000 000 000
OUTLINECOLOR 199 199 199
END
END
END
END
# =================================== debug.log
FreeBSD [/usr/local/www/cgi-bin/Maps]# cat ./debug.log
[Sat Feb 11 19:02:01 2012].3032 CGI Request 1 on process 2663
[Sat Feb 11 19:02:01 2012].10325 msDrawMap(): rendering using
outputformat named png (AGG/PNG).
[Sat Feb 11 19:02:01 2012].10365 msDrawMap(): WMS/WFS set-up and query, 0.000s
[Sat Feb 11 19:02:01 2012].10388 msDrawMap(): Drawing Label Cache, 0.000s
[Sat Feb 11 19:02:01 2012].10398 msDrawMap() total time: 0.007s
[Sat Feb 11 19:02:01 2012].76893 msSaveImage(stdout) total time: 0.066s
[Sat Feb 11 19:02:01 2012].77721 mapserv request processing time
(loadmap not incl.): 0.075s
[Sat Feb 11 19:02:01 2012].77749 msFreeMap(): freeing map at 0x29879800.
[Sat Feb 11 19:02:01 2012].77839 msPostGISLayerIsOpen called.
