[mapserver-users] Trouble connecting to PostGIS
Brent Fraser bfraser at geoanalytic.com
Mon Feb 13 13:24:43 PST 2012
Bob,
   Typical problems are
         - the connecting user (postgisuser) does not have privilege to
access the table
         - coordinate system is not specified in data (SRID=-1) and not
in the mapfile either
         -  and others
Turn on the layer debug logging by adding
DEBUG 5
to your mapfile and looking a the log.  You can also execute the SQL
statements shown in the log file using pgAdmin's SQL tool to see
additional information.
Best Regards,
Brent Fraser
On 2/13/2012 2:11 PM, Bistrais, Bob wrote:
> First of all, let me state that I am brand new to PostGIS and don't
> know much about what I'm doing with it.  That being said, I am having
> trouble displaying a PostGIS layer through MapServer.
> Right now I'm just experimenting with PostGIS and simply trying to get
> a layer to display.  I installed the Postgre and PostGIS 1.5.  I used
> the shapefile loader to convert a couple shapefiles to PostGIS data.
> Looking in pgAdmin, I see the tables do indeed exist for these layers.
> So I built a MapServer map file.  Here is my connection strings:
> DATA "the_geom from MylayerPoly"
> CONNECTION "user=postgisuser password=MyPassword! dbname=postgistest
> host=localhost port=5432"
> CONNECTIONTYPE postgis
> But the layer does not display.  Incidentally, I'm using GeoMoose as a
> front end for testing, but that shouldn't matter here.
> I did a mapserv --v at commandline, and I see the parameter INPUT=POSTGIS.
> So as far as I know it should work. Can anyone offer suggestions as to
> what I'm doing wrong?
> Thanks,
> Bob
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120213/9c071b91/attachment.html
