[mapserver-users] Trouble connecting to PostGIS
Puneet Kishor punk.kish at gmail.com
Mon Feb 13 14:05:42 PST 2012
On Feb 13, 2012, at 3:35 PM, Bistrais, Bob wrote:
> Thanks Brent.  The postgis user SHOULD have access to the table, as that
> is the table's owner.  Coordinate system is in the map file under
> Projection.
> Here is what the debug log showed me (Metwp100Poly is the actual name of
> the table, and MAINE is the layer name):
> [Mon Feb 13 16:31:32 2012].453000 CGI Request 1 on process 1300
> [Mon Feb 13 16:31:32 2012].687000 msPOSTGISLayerRetrievePGVersion():
> Query error. Error executing POSTGIS statement
> (msPOSTGISLayerRetrievePGVersion():select substring(version() from 12
> for (position('on' in version()) - 13))
> [Mon Feb 13 16:31:32 2012].687000 prepare_database(): Query error. Error
> declaring cursor: ERROR:  relation "metwp100poly" does not exist
The error above is telling you that it can't even find the said table.
Can you SELECT from this table successfully in PgAdmin?
Is it in a different schema than public, and perhaps that schema is not in the searchpath?
Does the postgisuser have access to this table?
Puneet Kishor
