[mapserver-users] Trouble connecting to PostGIS
Brent Fraser
bfraser at geoanalytic.com
Mon Feb 13 14:27:42 PST 2012
And I seem to recall needing to give some privileges on the
spatial_ref_sys and geometry_columns tables to the user.
Best Regards,
Brent Fraser
On 2/13/2012 3:05 PM, Puneet Kishor wrote:
> On Feb 13, 2012, at 3:35 PM, Bistrais, Bob wrote:
>> Thanks Brent. The postgis user SHOULD have access to the table, as that
>> is the table's owner. Coordinate system is in the map file under
>> Projection.
>> Here is what the debug log showed me (Metwp100Poly is the actual name of
>> the table, and MAINE is the layer name):
>> [Mon Feb 13 16:31:32 2012].453000 CGI Request 1 on process 1300
>> [Mon Feb 13 16:31:32 2012].687000 msPOSTGISLayerRetrievePGVersion():
>> Query error. Error executing POSTGIS statement
>> (msPOSTGISLayerRetrievePGVersion():select substring(version() from 12
>> for (position('on' in version()) - 13))
>> [Mon Feb 13 16:31:32 2012].687000 prepare_database(): Query error. Error
>> declaring cursor: ERROR: relation "metwp100poly" does not exist
> The error above is telling you that it can't even find the said table.
> Can you SELECT from this table successfully in PgAdmin?
> Is it in a different schema than public, and perhaps that schema is not in the searchpath?
> Does the postgisuser have access to this table?
> Puneet Kishor_______________________________________________
> mapserver-users at lists.osgeo.org
