[mapserver-users] Mapcache Seed / libpng error?
Andrew Cowie
CowieA at landcareresearch.co.nz
Tue Feb 14 19:45:53 PST 2012
Hello List,
We've been using mapcache_seed ( mapcache SVN checkout 13002 ) to build our caches mostly successfully so far, but recently have come up against an error which has only cropped up with a certain layer which includes our text & labels
www-data at server$ ./mapcache_seed -c /opt/mapserver/mapcache/oe_mapcache.xml -t 2012-02-02_text_cache_nztm -g portalgridnztm1 -z 7,8
found old lockfile /tmp/_gc_lock9-175-1233-slope_cache_nztm.lck, deleting it
found old lockfile /tmp/_gc_lock7-7-9-2012-02-02_text_cache_nztm.lck, deleting it
found old lockfile /tmp/_gc_lock9-136-179-terr_auth_cache_nztm.lck, deleting it
found old lockfile /tmp/_gc_lock9-138-86-wards_cache_nztm.lck, deleting it
seeding tile 65 25 7libpng error: IDAT: CRC error
failed to setjmp(png_jmpbuf(png_ptr))
failed to load image data from metatile
seeding tile 130 50 8
www-data at server$
or...
www-data at server$ ./mapcache_seed -c /opt/mapserver/mapcache/oe_mapcache.xml -t 2012-02-02_text_cache_nztm -g portalgridnztm1 -z 6,7
found old lockfile /tmp/_gc_lock9-137-51-terr_auth_cache_nztm.lck, deleting it
found old lockfile /tmp/_gc_lock9-182-1201-slope_cache_nztm.lck, deleting it
found old lockfile /tmp/_gc_lock9-138-197-wards_cache_nztm.lck, deleting it
seeding tile 25 15 6libpng warning: Ignoring bad adaptive filter type
seeding tile 50 35 7failed to setjmp(png_jmpbuf(png_ptr))
www-data at server$
The next step will be to checkout the latest SVN version. But we are currently mid-build with some other layers, so are waiting for them to finish before we do that. But thought we'd fire it out to the list to see if anyone has any ideas as to what might be causing this?
Below is the mapcache config:
<source name="src_text_update" type="wms">
<http>
<url>http://server/cgi-bin/mapserv601?</url>
</http>
<getmap>
<params>
<FORMAT>image/png</FORMAT>
<LAYERS>text</LAYERS>
<MAP>/opt/mapserver/mapfiles/m6scenz_topo_new.map</MAP>
<TRANSPARENT>true</TRANSPARENT>
</params>
</getmap>
</source>
<tileset name="2012-02-02_text_cache_nztm">
<source>src_text_update</source>
<cache>disk</cache>
<format>PNG</format>
<grid>portalgridnztm1</grid>
<metatile>5 5</metatile>
<metabuffer>10</metabuffer>
</tileset>
"labelcache_map_edge_buffer" "-10" is set in mapserver WEB METADATA
Cheers
Andrew
Please consider the environment before printing this email
Warning: This electronic message together with any attachments is confidential. If you receive it in error: (i) you must not read, use, disclose, copy or retain it; (ii) please contact the sender immediately by reply email and then delete the emails.
The views expressed in this email may not be those of Landcare Research New Zealand Limited. http://www.landcareresearch.co.nz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120215/48fd07bf/attachment-0001.html
