[mapserver-users] CONFIG "ON_MISSING_DATA" "IGNORE" does not work
on 5.6.8
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Feb 15 13:43:16 PST 2012
I can not get CONFIG "ON_MISSING_DATA" "IGNORE" to work on mapserver
5.6.8. I'm doing WMS requests and I get the error on the image.
MapServer version 5.6.8 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
The map file has:
CONFIG MS_ERRORFILE "stderr"
WEB
METADATA
labelcache_map_edge_buffer "-10"
ows_title "Peru_900913_WMS"
ows_onlineresource
"http://example.com/cgi-bin/mapserv?map=/u/data/peru.map&"
ows_srs "EPSG:4326 EPSG:900913"
ows_feature_info_mime_type "text/html"
ows_enable_request "GetMap"
# I tried this also, but error message still inimage.
# ows_exceptions_format "application/vnd.ogc.se_xml"
END
END
Seems like CONFIG "ON_MISSING_DATA" "IGNORE" should do what the doc says
it should do, but I can't find the magic incantation to make this work.
Anyone know how to do this?
-Steve W
