[mapserver-users] PHP max_input_vars can effect Mapbender administration and block requests
Astrid Emde astrid.emde at wheregroup.com
Thu Feb 16 03:03:49 PST 2012
sorry, wrong list.
A.
Am 16.02.2012 11:33, schrieb Astrid Emde:
> Hello,
> some of you may have problems saving changes within the Mapbender
> administration for example when you have a WMS with many layers. I
> wrote a mail before about Suhosin blocking requests when the
> Suhosin-variables are set too restrictive  [1].
> The problem can also occur, when the PHP variable max_input_vars [2]
> is not set.
> You may get a log message like this:
> "PHP Warning:  Unknown: Input variables exceeded 1000. To increase the
> limit change max_input_vars in php.ini."
> The default of this variable is 1000. If you have WMS with many layer
> you may have to increase this variable.
> I added this information to the Mapbender wiki [3][4].
> [1]
> http://lists.osgeo.org/pipermail/mapbender_users/2011-December/004046.html
> [2] http://php.net/manual/en/info.configuration.php
> [3] http://mapbender.org/PHP_Configuration#PHP_Configuration
> [4] http://mapbender.org/Suhosin
