[mapserver-users] draw line readinf from mysql
Murat Beyhan
beyhan at deprem.gov.tr
Tue Feb 21 00:18:40 PST 2012
Dear Robert,
Thanks for your reply,
Actually I have tried your suggestion but I could not succeed.
as follows in .map file directly
and in MySQL database I created a lineview view as follows
create view lineview as select eq_id, "LINESTRING(" + lon1 + " " + lat1
+ "," + lon2 + " " + lat2 + ")" as geom from sfault
in map file
I changed Geometrytype from wkbline to wkblinestring.
LAYER
NAME sfault1
connectiontype ogr
CONNECTION '<OGRVRTDataSource>
<OGRVRTLayer name="lineview">
<SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
<SrcLayer>lineview</SrcLayer>
<GeometryType>wkbLineString</GeometryType>
<GeometryField encoding="WKT" field="geom"/>
<LayerSRS>WGS84</LayerSRS>
<FID>eq_id</FID>
</OGRVRTLayer>
</OGRVRTDataSource>'
# <SrcDataSource>ODBC:user/passwd at DSN</SrcDataSource>
DATA sfault1
STATUS on
TYPE line
CLASS
name "Source Fault"
SYMBOL "cline"
SIZE 3
COLOR 0 0 255
END
END
There is an another issue I have to make a query in layer because I
select only one line from database so I have try to add SQL statement. I
'm not good at OGR GDAL so I need some advice and help.
Thank you for your interest
On Tue, 2012-02-21 at 09:15 +1300, Robert Sanson wrote:
> Hi Murat
> Is it possible for you to create a view from the columns that presents the data as a WKT line feature:
> create view lineview as select id, "LINESTRING(" + lon1 + " " + lat1 + "," + lon2 + " " + lat2 + ")" as geom from mytable
> Then set up your OGR ovf file representing this view:
> <OGRVRTDataSource>
> <OGRVRTLayer name="fences">
> <GeometryType>wkbLine</GeometryType>
> <LayerSRS>EPSG:2193</LayerSRS>
> <FID>id</FID>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Best wishes,
> Robert
> >>> Murat Beyhan <beyhan at deprem.gov.tr> 21/02/2012 2:52 a.m. >>>
> Dear friend,
> I'm trying to draw a line using MySql database
> the table in database as follows,
> id lat1 lon1 lat2 lon2
> 20100308023229 40.1113 38.7901 40.0311 38.7428
> actually using ogr connection I can draw point using ogr and mysql, but
> How can I draw line using such database table, please help me and give
> the idea...
> Thanks
> Murat
> Murat BEYHAN
> Geophysical Engineer, M.Sc.
> Prime Ministry
> Disaster and Emergency Management Presidency
> Earthquake Department
> Address: Eskisehir Yolu 12. Km.
> Lodumlu/ANKARA
> Tel: 312 2872680-1556
> email:beyhan at deprem.gov.tr
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> mapserver-users at lists.osgeo.org
> This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense Hosted Security.
> www.websense.com
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Afet ve Acil Durum Yönetimi Başkanlığı
Deprem Dairesi Başkanlığı
Eskişehir Yolu 12. Km.
Lodumlu/ANKARA
