[mapserver-users] WCS server not
Stephan Meißl
stephan at meissl.name
Wed Feb 22 00:50:52 PST 2012
On Tue, 2012-02-21 at 13:11 +0100, Jorge Lopez wrote:
> Hello;
> I am newbie to Mapserver, so maybe this is a naive question but I am
> doing my best to find a solution to serve raster data by using
> Mapserver.
> I have MapServer 5.6.5, I have prepared my map server with WFS and WMS
> and I would like to serve GEOTIFF images with WCS 1.0.0 protocol.
> I prepared a map file, with two layers to be served and I made a
> capabilities of the server:
> http://domainserver/cgi-bin/mapserv?SERVICE=WCS&VERSION=1.0.0&REQUEST=GetCapabilities
> The problem is that all metadata is full but there is no content for
> coverages ("identifiers" in v.1.1.0), that is, the content between
> ContentMetada labels is empty,
> <ContentMetadata>
> </ContentMetadata></WCS_Capabilities>
> So I don't know what is happen, I made a probe like using shp2img to
> generate a image png from mapfile and it is done
> My Mapfile (only one layer) looks like in the following way:
> MAP
> NAME "xxxx Map Server"
> SIZE 100 100 # NECESARIO PARA LA UTILIDAD shp2img
> UNITS DD
> EXTENT -90 -90 90 90
> DEBUG 5
> CONFIG "CPL_DEBUG" "ON"
> CONFIG "MS_ERRORFILE" "/tmp/mapserver.log" #a este fichero van
> mensajes de error!! (equivalent to set SetEnv MS_ERRORFILE
> "/tmp/mapserver.log" in /etc/apache2/apache2.conf)
> PROJECTION
> "init=epsg:4326"
> END # end projection
> # Background color for the map canvas -- change as desired
> IMAGECOLOR 192 192 192
> IMAGEQUALITY 95
> IMAGETYPE jpeg
> # Usamos el driver GDAL para crear el formato Ráster en modo IMAGEN
> RGB
> OUTPUTFORMAT
> NAME GEOTIFF_RGB
> DRIVER "GDAL/GTiff"
> MIMETYPE "image/tiff"
> IMAGEMODE RGB
> EXTENSION 'tif'
> END #end outputformat
> # Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END #end label
> END #end legend
> # Web interface definition. Only the template parameter is required
> to display a map. See MapServer documentation
> WEB
> # Set IMAGEPATH to the path where MapServer should write its
> output.
> IMAGEPATH '/tmp/'
> # Set IMAGEURL to the url that points to IMAGEPATH as defined in
> your web server configuration
> IMAGEURL '/tmp/'
> # WCS server settings
> METADATA
> 'wms_title' 'xxxx Map Server'
> 'wms_enable_request' '*'
> 'ows_onlineresource' 'http://domainserver/cgi-bin/mapserv?'
> #'ows_srs' 'CRS:84 EPSG:4326
> urn:x-ogc:def:crs:EPSG:4326 urn:x-ogc:def:crs:EPSG:3035 EPSG:3035
> EPSG:4258'
> 'ows title' 'Intamap WCS'
> urn:x-ogc:def:crs:EPSG:4326'
> 'ows_abstract' 'Comentarios Blah Blah Blah'
> #'ows_srs' 'EPSG:3035 urn:x-ogc:def:crs:EPSG:3035'
> 'wfs_title' 'xxxx WFS Server'
> 'wfs_onlineresource' 'http://domainserver/cgi-bin/wfs?'
> 'wfs_srs' 'EPSG:4326' ## Recommended
> 'wfs_abstract' 'Web Feature Service for the XXXX central
> geonode.' ## Recommended
> 'wfs_enable_request' '*'
> 'wms_abstract' 'Web Map Service for the XXXX central
> geonode'
> ###### WCS ################
> 'wcs_label' 'XXXX WCS Server' ### required for WCS
> 'wcs_title' 'XXX Web Coverage Service Server'
> 'wcs_description' 'Web Coverage Service for the XXXX
> central geonode to serve coverages'
> 'wcs_onlineresource' 'http://domainserver/cgi-bin/wcs?'
> 'wcs_service_onlineresource' 'http://domainserver/cgi-bin/wcs?'
> 'wcs_fees' 'none'
> 'wcs_srs' 'EPSG:4326' ## Recommended
> # 'wcs_abstract' 'Web Coverage Service for the XXXXXX
> central geonode.' ## Recommended
> 'wcs_accessconstraints' 'none'
> 'wcs_keywordlist' 'WCS, TEXT, Coverage'
> 'wcs_metadatalink_format' "text/plain" #tipo MIME para formato
> de ficheros
> 'wcs_metadatalink_href' "http://domainserver/catalog" # URL
> al metadata
> 'wcs_metadatalink_type' "TC211" # standard que cumple el
> metadata
> "wcs_address" "124 Gilmour Street"
> "wcs_city" "Ottawa"
> "wcs_stateorprovince" "ON"
> "wcs_postcode" "90210"
> "wcs_country" "Canada"
> "wcs_contactelectronicmailaddress" "blah at blah"
> "wcs_contactperson" "me"
> "wcs_contactorganization" "unemployed"
> "wcs_contactposition" "manager"
> "wcs_contactvoicetelephone" "613-555-1234"
> "wcs_contactfacimiletelephone" "613-555-1235"
> # "wcs_service_onlineresource"
> "http://domainserver/cgi-bin/wcs?"
> 'wcs_enable_request' '*'
> END #end metadata
> #Scale range at which web interface will operate
> # Template and header/footer settings
> # Only the template parameter is required to display a map. See
> END #end web
> LAYER
> NAME 'GLOBCORINE_Color'
> TYPE RASTER
> STATUS ON
> METADATA
> 'wms_title' 'GLOBCORINE_2009'
> # 'ows_metadataurl_format' 'text/html'
> # 'ows_metadataurl_href' 'http://domainserver/catalog'
> # 'ows_metadataurl_type' 'TC211'
> 'wcs_label' 'GLOBCORINE 2009'
> 'wcs_formats' 'GEOTIFF'
> 'wcs_rangeset_name' 'Range 1' ### required to support
> DescribeCoverage request
> 'wcs_rangeset_label' 'Globcorine 2009 classes' ###
> required to support DescribeCoverage request
> END #end metadata
> DATA '/path/GLOBCORINE_Color.tif'
> # PROJECTION
> # 'proj=longlat'
> # 'ellps=WGS84'
> # 'datum=WGS84'
> # 'no_defs'
> # END #end projection
> # DUMP TRUE
> END #end layer
> END #end map
> I have no xml capabilities file if I set DUMP TRUE in LAYER class,
> there is a internal server error according to Apache.
> I don`t know if there is a problem with GDAL library or not. I am just
> be confussed
> Any help would be very appreciate.
> Thank you in advance
> Jorge
Jorge,
AFAIK "DUMP True" is needed in MS 5.6.5 to enable WCS. Did you try to
enable debugging [1] to see what's causing the error? Depending on your
data you might need the to set the "wcs_extent" metadata but this should
be reported in the debug output.
cu
Stephan
[1] http://www.mapserver.org/optimization/debugging.html
