[mapserver-users] Re: WCS server not
Stephan Meißl
stephan at meissl.name
Wed Feb 22 02:29:40 PST 2012
On Wed, 2012-02-22 at 01:57 -0800, jorgelopez wrote:
> Hello Stephan,
> As you said, I have seen that for Mapserver version it is advisbale to write
> DUMP TRUE in (layer-level) map file but there is no capabilities in the web
> browser. 505 Internal Server Error and the following message:
> The server encountered an internal error or misconfiguration and was unable
> to complete your request.
> Please contact the server administrator, etclusi.gis.support at uab.es and
> inform them of the time the error occurred, and anything you might have done
> that may have caused the error.
> More information about this error may be available in the server error log.
> I did all related with debug issues and I am obtaining errors to log file
> saying
> "[Wed Feb 22 09:44:53 2012] [error] [client 158.109.144.146] Premature end
> of script headers: mapserv"
> According to this, I checked not to be in conflict with INPUT=GDAL and
> INPUT=TIFF
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> I am trying to serve two TIFF Images, one with 1 band and a colour palette
> (Land Cover) and another one, Murble Nasa image and 3 bands RGB. So at this
> point I dont know if there is a conflict with GDAL library (I dont think so
> because shp2img -m file.map -o test.png -all_debug 5 reports in a correct
> direction) or one parameters wcs_* related is missing in METADATA section.
> Could you give any above-mentioned not explored tips or directly go to MSv6?
> Thanks you in advance
> Jorge
Could you please post the debug messages when you set "DEBUG 5" both on
mapfile and layer level?
Thanks,
Stephan
