[mapserver-users] mapserver / gdal draw failure
Thu Feb 23 10:31:23 PST 2012
On Thu, Feb 23, 2012 at 7:05 AM, Aaron Sims <apsims at ncsu.edu> wrote:
> gdalinfo on the tiff files yields:
Aaron,
You might want to try:
  gdalinfo -mm /home/cache/2012021913-2012022013.tif
This will force actual reading of the imagery blocks to compute
a min/max for each band and will help determine if there is any
problem with the imagery.  I don't really understand your overall
process well, but I am suspicious there might be an issue where
whatever is writing the .tif file is not quite finished flushing it out
before you are trying to read it with mapserver.  The error is what
I might expect from reading an unflushed TIFF file.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
and watch the world go round - Rush    | Geospatial Software Developer
