[mapserver-users] draw line readinf from mysql
Murat Beyhan
beyhan at deprem.gov.tr
Fri Feb 24 02:38:29 PST 2012
Dear all,
Still could not achieve to draw line using start and stop point line
data stored in MySql database.
I have tried Mr. Robert's solution but I have faced an error message.
in map file
I changed Geometrytype from wkbline to wkblinestring.
LAYER
NAME sfault1
CONNECTIONTYPE OGR
CONNECTION '<OGRVRTDataSource>
<OGRVRTLayer name="lineview">
<SrcDataSource>MYSQL:dynamic,user=root,password=mysqlpasswd,host=localhost,port=3306,tables=lineview</SrcDataSource>
<SrcLayer>lineview</SrcLayer>
<GeometryType>wkbLineString</GeometryType>
<GeometryField encoding="WKT" field="geom"/>
<LayerSRS>WGS84</LayerSRS>
<FID>eq_id</FID>
</OGRVRTLayer>
</OGRVRTDataSource>'
DATA sfault1
STATUS on
TYPE line
CLASS
NAME "Source Fault"
SYMBOL "cline"
SIZE 3
COLOR 0 0 255
END
END
in database
I have two table
one is store id lat1 lon1 lat2 lon2
and another is view
of this table created by following
create view lineview as select eq_id, "LINESTRING(" + lon1 + " " + lat1
+ "," + lon2 + " " + lat2 + ")" as geom from sfault
there is an another issue,
I have to draw line by considering id
so in the map When I select one id, line should be belong to this id's
information
so I have to make a sql statement as follow instead of draw all line
stored in database I have to draw just one line considering id
something like this select eq_id, geom from lineview where id like '%id
please help about this subject....
Regards....
Murat
On Tue, 2012-02-21 at 09:15 +1300, Robert Sanson wrote:
> Hi Murat
> Is it possible for you to create a view from the columns that presents the data as a WKT line feature:
> create view lineview as select id, "LINESTRING(" + lon1 + " " + lat1 + "," + lon2 + " " + lat2 + ")" as geom from mytable
> Then set up your OGR ovf file representing this view:
> <OGRVRTDataSource>
> <OGRVRTLayer name="fences">
> <SrcDataSource>ODBC:user/passwd at DSN</SrcDataSource>
> <GeometryType>wkbLine</GeometryType>
> <LayerSRS>EPSG:2193</LayerSRS>
> <FID>id</FID>
> </OGRVRTLayer>
> </OGRVRTDataSource>
> Best wishes,
> Robert
> >>> Murat Beyhan <beyhan at deprem.gov.tr> 21/02/2012 2:52 a.m. >>>
> Dear friend,
> I'm trying to draw a line using MySql database
> the table in database as follows,
> 20100308023229 40.1113 38.7901 40.0311 38.7428
> actually using ogr connection I can draw point using ogr and mysql, but
> How can I draw line using such database table, please help me and give
> the idea...
> Thanks
> Murat
> Murat BEYHAN
> Geophysical Engineer, M.Sc.
> Prime Ministry
> Disaster and Emergency Management Presidency
> Earthquake Department
> Address: Eskisehir Yolu 12. Km.
> Lodumlu/ANKARA
> Tel: 312 2872680-1556
> email:beyhan at deprem.gov.tr
> This message has been scanned for viruses and
> dangerous content by MailScanner, and is
> believed to be clean.
> mapserver-users at lists.osgeo.org
> This email and any attachments are confidential and intended solely for the addressee(s). If you are not the intended recipient, please notify us immediately and then delete this email from your system.
> This message has been scanned for Malware and Viruses by Websense Hosted Security.
> www.websense.com
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Afet ve Acil Durum Yönetimi Başkanlığı
Deprem Dairesi Başkanlığı
Eskişehir Yolu 12. Km.
Lodumlu/ANKARA
