[mapserver-users] UTF-8 right to left text
Ian Walberg ian.walberg at airborne.aero
Sun Feb 26 21:20:07 PST 2012
Jukka,
I had seen that and we are hoping to test it this week.
Regards
Ian
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Rahkonen
Jukka
Sent: Sunday, February 26, 2012 9:12 PM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] UTF-8 right to left text
Did you know that the fresh Spatialite-gui (v. 3.0.1) can import data
directly from Excel?
-Jukka Rahkonen-
________________________________________
 Ian Walberg wrote:
> Steve,
> Many thanks for getting back to me.
> We have built with that version of fridibi and do get some text labels
displaying correctly.
> The source data is from an excel spread sheet which we export to CSV
> and
import into the SQLite DB.
> The plan tomorrow is to find a couple of good and bad labels and
> follow
these through to see if we can find where there are differences, I
looked last week at the hex codes for a good and bad name but did not
come to any clear confusion.
> Does fribidi need  RTL code to display the text correctly? Do you know
how to decode that from the hex?
> Regards
Ian
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Stephen
Woodbridge
Sent: Sunday, February 26, 2012 8:52 PM
On 2/26/2012 10:39 PM, Ian Walberg wrote:
> Hello lists,
> We cannot get all our Arabic text labels to display correctly, it
> appears that the incorrectly rendered text is not being drawn right to
> left. Some work and others do not.
> Our assumption is that there are some non displaying codes we are
> missing but we do not know enough yet to work out if this is the case.
> The data is in an sqlite database using an OGR connection.
> Any ideas or experience that you can share would be fabulous.
Ian,
You need the follow pieces to get this to work:
1. make sure you have built mapserver with fribidi-0.19.2 2. you need a
ttf that supports the character set you are using
    - I always make sure my data is in UTF8
    - and I have a unicode arial.ttf font from Windows 3. make sure your
LABEL block has ENCODING "UTF8" in it
    - assuming your data is in UTF8
On Linux you can do:
$ dbfdump myshapefile.dbf > aaa
$ file aaa
and it will tell you what the encoding is.
Issues that I have run into are:
1. data with mixed utf8 and other encodings like Window-1256 or
ISO-8859-6 2. In UTF8 data there are a lot of glyphs that are connecting
characters or non printing characters and many fonts do not have glyphs
defined for these characters which typically causes a square box to be
displayed.
-Steve W
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
