[mapserver-users] OGR and MSSQL non-specific error
Tamas Szekeres
szekerest at gmail.com
Mon Feb 27 13:58:41 PST 2012
2012/2/26 Anzel, Phil - NRCS, Fort Collins, CO <Phil.Anzel at ftc.usda.gov>
> 1. Note that I omitted the “tables=…” as it appears that naming a specific
> table would interfere with connection pooling if I’m using many layers
> drawing data from different tables. Do I understand the role of the
> “tables=…” incorrectly?****
Yes, it may be considered as being a different connection if the tables
section is used.
> 2. I added the explicit spatial filtering (STIntersects…). Is there a
> better way to do this?****
It seems to be a bit complicated this way. I think you should try simply
setting the layer name in the DATA section. In this case the spatial filter
is added automatically by the MapServer OGR driver.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120227/34756c21/attachment.html
