[mapserver-users] mapserver palette color
jorgelopez
jorgelopez.physics at gmail.com
Tue Feb 28 00:44:25 PST 2012
Hello everyone:
I am trying to serve tiff images with mapserver by using mapserver v.5.6.5
with WCS implemented protocol v.1.0.0. All is fine in the sense that
three-band raster are served correctly with a WCS client (RGB composite
renderer with ArcMap, for instance). BUT if I want to display a single band
raster with a palette color describing some (discrete) categories, for
instance, a thematic raster layer (Corine -- Use and Land covers), the
connection to WCS server by using WCS client is fine, but the image is
served like a continuos band range instead a discrete colors as
corresponding to color table. So my WCS client is not detecting inherent
properties in the raster data.
So, at this point I have some doubts:
*my mapfile is not well defined
*the protocol does not support this and is not suited to serve discrete
(unique) values
*I am ignorant about how is rendered images with Mapserver
Maybe third part is the correct statement. As far as I know built-in libs
and GDAL is responsible for rendering raster in Mapsserver. My CGI bin is
compiled with GDAL support, so raster will be managed by it; gdalinfo
<filename> gives me information about raster layer (land cover) showing a
color table with a single band and 255 entries (only 13 categories with
different colours). Questions that throw some light for me because I have
not found clear directions in docs.
I dont know if I have to specify CLASS definition for pixels that indicates
classification of pixels in raster (like in ref
http://mapserver.org/input/raster.html#how-are-rasters-added-to-a-map-file)
could be tedious and I didn´t get it.
- I have defined OUTPUTFORMAT object in my mapfile like this:
OUTPUTFORMAT
NAME 'GEOTIFF'
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
# IMAGEMODE 'INT16'
# IMAGEMODE 'PC256'
IMAGEMODE 'BYTE'
EXTENSION 'tif'
END #end BANDS
but by using IMAGEMODE 'BYTE' it is rendered like a single-band image with
a greyscale (continuous but not discrete). In docs
(http://mapserver.org/ogc/wcs_format.html) I have read that IMAGEMODE
'PC256' is needed to serve images with a color table and one single band.
- I ignore PROCESSING directive. I dont know if a I should to indicate that
how to partitioning band like this
PROCESSING "SCALE=0,255"
PROCESSING "SCALE_BUCKETS=XXX"
to obtain a color table as raster definition.
- 'wcs_band_count' '1'
'wcs_nativeformat' '8-bit GeoTIF'
Does anyone know how to indicate mapserver to serve raster as 'raw data' ?
Some trends how to do it and getting out with this are wellcome.
Jorge
View this message in context: http://osgeo-org.1560.n6.nabble.com/mapserver-palette-color-tp4520887p4520887.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
