[mapserver-users] WMS for netcdf [SEC=UNCLASSIFIED]
Kathleen Hirst K.Hirst at bom.gov.au
Tue Feb 28 14:52:40 PST 2012
Hi Puneet,
I tried the variable substitution and it didn't work as I don't think PROCESSING is one of the parameters supported.
I also looked at the link about WCS, but I only want WMS. I'm not sure how a tile index would work as I'm only using one file with multiple time bands.
Plus, I looked at "Changing map file parameters via a form or a URL", but wasn't sure of the syntax to change the band number.
Thanks
Kathleen
From: Puneet Kishor [mailto:punk.kish at gmail.com]
Sent: Wednesday, 29 February 2012 2:14 AM
To: Kathleen Hirst
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WMS for netcdf [SEC=UNCLASSIFIED]
On Feb 27, 2012, at 10:29 PM, Kathleen Hirst <K.Hirst at bom.gov.au<mailto:K.Hirst at bom.gov.au>> wrote:
Dear List,
I have a NetCDF file with contains over 150 timesteps. I can create a WMS for each timestep using PROCESSING "BANDS=1", which means I have to define over 150 layers. I was hoping to only define the layer once and pass a variable for the time or the band number.
Does anyone have any ideas?
Kathleen,
I wrote the following reply, and then realized that you may not be asking for this. Have you seen http://mapserver.org/ogc/wcs_format.html?
For completeness, I will leave my original response as well.
Kathleen,
Neither have I done this before nor do I know the answer, but I *am* interested in how you solve it since I have interest in munging a bunch of netCDF data. I am wondering, couldn't you use the standard variable substitution as Mapserver supports that for stuff like layer names and class names? Something like (do check the exact syntax)
PROCESSING "BANDS=%band%"
and then past in the band via the query string ?band=1
http://mapserver.org/mapfile/variable_sub.html
Puneet Kishor
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120229/1352c650/attachment.html
