[mapserver-users] MapCache compilation error;
ld cannot find libraries
thomas bonfort
thomas.bonfort at gmail.com
Mon Jan 2 09:18:48 EST 2012
hmm, the apxs2 command does seem to need the -Wl flag passed to it
thomas
On Mon, Jan 2, 2012 at 14:41, Armin Burger <armin.burger at gmx.net> wrote:
> Thomas
> thanks a lot for the quick help.
> OS is Ubuntu 10.04 64bit, libtool version is 2.2.6b.
> I made the changes as you suggested and compilation continued. But then
> another error appeared:
> /usr/bin/apxs2 -Wc," -DUSE_MEMCACHE -DUSE_PCRE -DUSE_OGR -DUSE_GEOS
> -DUSE_SQLITE -DUSE_PIXMAN -DLINUX=2 -D_REENTRANT -D_GNU_SOURCE -pthread
> -O2 -Wall -fPIC -DHAVE_SYMLINK -DNDEBUG -I../include -I/usr/include/apr-1.0
> -I/usr/include/apr-1.0 -I/usr/include/pixman-1 " -lcurl -lpng -ljpeg
> /usr/lib/libapr-1.la /usr/lib/libaprutil-1.la -lpcre -lsqlite3 -lpixman-1
> -c mod_mapcache.c libmapcache.la
> Usage: apxs -g [-S <var>=<val>] -n <modname>
> apxs -q [-S <var>=<val>] <query> ...
> apxs -c [-S <var>=<val>] [-o <dsofile>] [-D <name>[=<value>]]
> [-I <incdir>] [-L <libdir>] [-l <libname>] [-Wc,<flags>]
> [-Wl,<flags>] [-p] <files> ...
> apxs -i [-S <var>=<val>] [-a] [-A] [-n <modname>] <dsofile> ...
> apxs -e [-S <var>=<val>] [-a] [-A] [-n <modname>] <dsofile> ...
> make[1]: *** [mod_mapcache.o] Error 1
> Armin
> On 02/01/2012 14:22, thomas bonfort wrote:
>> There have been some extensive changes in the build process over the
>> holidays. Please try editing src/Makefile, and replace the two
>> occurences of -Wl,"$(LIBS)" by $(LIBS).
>> If that fixes it, can you post the output of
>> /usr/share/apr-1.0/build/libtool --version, and your OS distribution
>> and version
>> thomas
