[mapserver-users] layerObj.setFilter parser error
    Lime, Steve D (DNR)
    Steve.Lime at state.mn.us
    Wed Jan 11 15:18:44 PST 2012
I don't know of a simple work around. MapScript and the mapfile parser use the same expression tokenizing routine. What happens if you try single quotes? That is:
   layerObj.setFilter (  '(point.id = 1)' )
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Radim Blazek
Sent: Tuesday, January 10, 2012 12:05 PM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] layerObj.setFilter parser error
If I use layerObj.setFilter (  "(point.id = 1)" ), mapObj.OWSDispatch
gives an error:
    "msTokenizeExpression(): Expression parser error. Parsing time value failed.
     msParseTime(): Regular expression error. Unrecognized date or
time format ()."
It works correctly with layerObj.setFilter (  "( id = 1)" ) or
layerObj.setFilter (  "point.id = 1" ).
FILTER "( point.id = 1 )" in mapfile also works.
This is of course only a simple example, I need both fully qualified
column name and parenthesis.
It seems to be a bug. Do you know any simple trick, how to get it
working for a presentation tomorrow morning?
Version 6.0.1.
Thanks
Radim
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
More information about the MapServer-users
