[mapserver-users] SLD filters in MS6
Havard Tveite
havard.tveite at umb.no
Fri Jan 13 14:53:38 EST 2012
This might be related to ticket #4112.
http://trac.osgeo.org/mapserver/ticket/4112
Håvard
On 13/01/12 11:51, Knut.Landmark at FFI.no wrote:
> Hi all,
> I want to do attribute dependent rendering using SLD with filters inside
> the <Rule> element, but cannot get it to work properly with MapServer
> 6.0.1 when the CONNECTIONTYPE is POSTGIS. However, all other things
> being equal, it works well with MapServer 5.2.1. It also works well with
> other data formats like GML or shape, in both versions of MapServer. Are
> there any changes in MapServer that I should be aware of that might
> affect how filters work?
> As an example, the attached figure1 shows the correct map generated by
> MS 5.2.1, while figure2 shows the MS 6.0.1 generated map in which all
> polygons get the same color. MS 6.0.1 uses the same PostGIS database and
> SLD file and an equivalent map file. In case it can provide any clues,
> my MS 5.2.1 generates SQL like this (from the log file):
> [Wed Jan 11 23:20:47 2012].319000 query_string_0_6:DECLARE mycursor
> BINARY CURSOR FOR SELECT
> "drval1"::text,"drval2"::text,asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),ogc_fid::text
> from ukcbut00.depare WHERE wkb_geometry &&
> setSRID('BOX3D(-1.57769913517149 50.6363909616681,-0.843360864828487
> 50.8899255935367)'::BOX3D, find_srid('','ukcbut00.depare','wkb_geometry') )
> The select command fetches the two attributes drval1 and drval2, on
> which the filters act, as well as the geometry. However, MS 6.0.1
> constructs SQL like this:
> [Wed Jan 11 22:22:06 2012].26000 msPostGISLayerWhichShapes query: select
> encode(ST_AsBinary(ST_Force_2D("wkb_geometry"),'NDR'),'hex') as
> geom,"ogc_fid" from ukcbut00.depare where wkb_geometry &&
> GeomFromText('POLYGON((-1.57514202386 50.6588672768767,-1.57514202386
> 50.9035127337513,-0.841117976140038 50.9035127337513,-0.841117976140038
> 50.6588672768767))',find_srid('','ukcbut00.depare','wkb_geometry')) and
> (( ("drval1"<= 0) OR ("drval1"<= 10) OR ("drval1"<= 20) OR ("drval1">=
> 20) ))
> (The clause ("drval1"<= 0) OR ("drval1"<= 10) OR ("drval1"<= 20) OR
> ("drval1">= 20) seems a bit odd and is true for all polygons.)
> Below I have included the SLD code in its entirety.
> Thanks,
> Knut
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <StyledLayerDescriptor version="1.0.0"
> xsi:schemaLocation="http://www.opengis.net/sld"
> xmlns="http://www.opengis.net/sld"
> xmlns:ogc="http://www.opengis.net/ogc"
> xmlns:xlink="http://www.w3.org/1999/xlink"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <NamedLayer>
> <Name>depare</Name>
> <UserStyle>
> <Title>AML Depth Area</Title>
> <FeatureTypeStyle>
> <Rule>
> <ogc:Filter>
> <ogc:PropertyIsLessThanOrEqualTo>
> <ogc:PropertyName>drval1</ogc:PropertyName>
> <ogc:Literal>0</ogc:Literal>
> </ogc:PropertyIsLessThanOrEqualTo>
> </ogc:Filter>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#B4EBFF</CssParameter>
> </Fill>
> </PolygonSymbolizer>
> </Rule>
> <Rule>
> <ogc:Filter>
> <And>
> <ogc:PropertyIsGreaterThanOrEqualTo>
> </ogc:PropertyIsGreaterThanOrEqualTo>
> <ogc:PropertyName>drval2</ogc:PropertyName>
> <ogc:Literal>10</ogc:Literal>
> </And>
> </ogc:Filter>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#66EBFF</CssParameter>
> <CssParameter name="fill-opacity">0.1</CssParameter>
> </Fill>
> </Rule>
> <Rule>
> <ogc:Filter>
> <And>
> <ogc:Literal>20</ogc:Literal>
> </And>
> </ogc:Filter>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#0097FF</CssParameter>
> </Fill>
> </Rule>
> <Rule>
> <ogc:Filter>
> </ogc:Filter>
> <PolygonSymbolizer>
> <Fill>
> <CssParameter name="fill">#2222FF</CssParameter>
> </Fill>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
