[mapserver-users] South pole projection issues
Fuchs Juan Carlos jfuch at indec.mecon.gov.ar
Mon Jan 16 14:33:56 EST 2012
Hi folks!
is there someone, who could translate this *.prj to some WKT
i could pass to Mapserver (projection) to get both maps, one over the
other??
this is my *.prj from the base-map, so to say.
PROJCS["Transverse
Mercator",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",63781
37.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943
3]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",3500000.0],P
ARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-66.0],PARAMETER
["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",-90.0],UNIT["Meter",1.0]
this is the snippet in WKT from my *.map file (Projection of the base-map)
            PROJECTION
              "proj=tmerc"
              "lat_0=-90"
              "lon_0=-66"
              "k=1"
              "x_0=3500000"
              "y_0=0"
              "ellps=WGS84"
              "datum=WGS84"
              "units=m"
            END
This is the *.prj from the shp i have, and need to bring along with the
other one.
PROJCS["lambert",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984
",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329
25199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easti
ng",10000000.0],PARAMETER["False_Northing",6391246.5],PARAMETER["Central_Mer
idian",-60.0],PARAMETER["Latitude_Of_Origin",-40.0],UNIT["Meter",1.0]]
that is my best try so far,: WKT from my *.map file layer (Projection)
            PROJECTION
                        "proj=laea"
                        "ellps=WGS84"
                        "lat_1=40"
                        "lon_0=-60"
                        "south"
            END
what can i say? it displays VERY ugly...
Thanks in advanced for any help/advice you can give me.
JC
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120116/c63961b5/attachment-0001.html
