[mapserver-users] Mapserver install - Mac OS X and safari
Rahkonen Jukka Jukka.Rahkonen at mmmtike.fi
Mon Jan 16 15:36:39 EST 2012
I don't know anything about Macs but http://localhost.com<http://localhost.com/> feels odd. Perhaps it should be just http://localhost?<http://localhost/?>
-Jukka Rahkonen-
M Badar wrote:
> Greetings,
> New user to the list.  I am installing mapserver on my MacBook Pro.  The installation has progressed without error until I attempt to call the 'mapserv' cgi executable from safari; it returns the following error after running the final check as described in the documentation:
> # Page 40, MapServer Documentation, Release 6.0.1; 4.1.8 Installation - The basic install.
# This is the final test to ensure mapserver is installed and functioning correctly.
# When attempting to access the test URL, safari returns the following error:
# Test URL: http://localhost.com/cgi-bin/mapserv
# Safari error:
# safari can't open the page "http://localhost.com/cgi-bin/mapserv" because the server
# unexpectedly dropped the connection.
Mapserver version: 6.0.1
Mac OS X version: 10.6.8
Safari version: 5.1.2
My suspicion is the error is related to how mapserver and apache are communicating; however, not being apache literate, I don't know where to begin diagnosing the connection problem.  I ran a syntax check on the httpd.conf file and it returned the following:
Michael-Badars-MacBook-Pro:bin bobby$ apachectl -t
httpd: Could not reliably determine the server's fully qualified domain name, using
Michael-Badars-MacBook-Pro.local for ServerName
Syntax OK
The above error is returned regardless if I am connected to the internet via a wireless or hardwired connection.
Listed below are details regarding my installation.
Thanks in advance for any help you can provide.
Mike Badar
# Map Server 6.0.1 "configure" script.
# Author: Mike Badar
# Date: 29 December, 2011
# Version: 3
./configure                                                       \
               --with-curl-config=/usr/local/bin/curl-config     \
               --with-gdal=/usr/local/bin/gdal-config            \
               --with-geos=/usr/local/bin/geos-config            \
               --with-ogr=/usr/local/bin/gdal-config             \
               --with-postgis=/usr/local/pgsql/bin/pg_config     \
               --with-xml2-config=/usr/local/bin/xml2-config     \
               --with-agg=/usr/local                             \
               --with-freetype=/usr/local                        \
               --with-gd=/usr/local                              \
               --with-httpd=/usr/local/apache2/bin/httpd         \
               --with-jpeg=/usr/local                            \
               --with-proj=/usr/local                            \
               --with-tiff=/usr/local                            \
               --with-wfsclient                                  \
               --with-wmsclient                                  \
               --with-threads                                    \
               --with-wcs                                        \
               --enable-debug
# Mapserver version.
Michael-Badars-MacBook-Pro:cgi-bin bobby$ ./mapserv -v
MapServer version 6.0.1 \
         OUTPUT=GIF \
         OUTPUT=PNG \
         OUTPUT=JPEG \
         SUPPORTS=PROJ \
         SUPPORTS=AGG \
         SUPPORTS=FREETYPE \
         SUPPORTS=ICONV \
         SUPPORTS=WMS_SERVER \
         SUPPORTS=WMS_CLIENT \
         SUPPORTS=WFS_CLIENT \
         SUPPORTS=WCS_SERVER \
         SUPPORTS=THREADS \
         SUPPORTS=GEOS \
         INPUT=OGR \
         INPUT=GDAL \
         INPUT=SHAPEFILE
# Page 39, MapServer Documentation, Release 6.0.1; Step 9 test.
This script can only be used to decode form results and
should be initiated as a CGI process via a httpd server.
# Apache version.
Michael-Badars-MacBook-Pro:bin bobby$ apachectl -v
Server version: Apache/2.2.20 (Unix)
Server built:   Sep 12 2011 17:42:56
# /usr/local/apache2/conf/httpd.conf; mapserver additions.
# ServerRoot
ServerRoot "/usr/local/apache2"
# Apache port.
Listen 80
# Cgi directory; ScriptAlias; Log file.
<Directory /usr/local/apache2/cgi-bin>
Options +ExecCGI +FollowSymLinks
</Directory>
ScriptAlias /cgi-bin/ /usr/local/apache2/cgi-bin/
# Log file.
ScriptLog logs/cgi_log
ErrorLog "logs/error_log"
# Display user 'www'
Michael-Badars-MacBook-Pro:~ root# dscl . -read /Users/www
AppleMetaNodeLocation: /Local/Default
AuthenticationAuthority: ;ShadowHash;
                         ;Kerberosv5;
                         ;_www at LKDC:SHA1.458017A5A4386C409A25B49470E08467DC7022AF
                         ;LKDC:SHA1.458017A5A4386C409A25B49470E08467DC7022AF;
GeneratedUID: FFFFEEEE-DDDD-CCCC-BBBB-AAAA00000046
NFSHomeDirectory: /Library/WebServer
Password: ********
PrimaryGroupID: 70
RealName:
World Wide Web Server
RecordName: _www www
RecordType: dsRecTypeStandard:Users
UniqueID: 70
UserShell: /usr/bin/false
# Check /usr/local/apache2/conf/httpd.conf for syntax errors.
Syntax OK
# Start apache and check for the existence of the httpd process.
Michael-Badars-MacBook-Pro:logs root# apachectl start
Michael-Badars-MacBook-Pro:logs root# ps -ajx|grep httpd
root       526     1   526 59ff000    0 Ss     ??    0:00.18 /usr/sbin/httpd -D FOREGROUND
_www       527   526   526 59ff000    0 S      ??    0:00.00 /usr/sbin/httpd -D FOREGROUND
root       529   391   528 5a00110    2 S+   s001    0:00.00 grep httpd
# Safari error:
# Port 80 /etc/services
http             80/udp     www www-http # World Wide Web HTTP
http             80/tcp     www www-http # World Wide Web HTTP
# /etc/services
Michael-Badars-MacBook-Pro:~ bobby$ cat /etc/hosts
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting.  Do not change this entry.
# 127.0.0.1 localhost
# This line was added in an attempt to diagnose why apache is dropping connections
# to mapserver.
127.0.0.1       localhost.localdomain   localhost # Mapserver diagnostic line.
255.255.255.255 broadcasthost
::1             localhost
fe80::1%lo0 localhost
