[mapserver-users] Mapserver install - Mac OS X and safari
M Badar
mikebadar.j at gmail.com
Mon Jan 16 20:06:25 EST 2012
Thanks, everyone.
With /etc/hosts set to:
127.0.0.1 localhost localhost
and accessing the URL:
http://localhost.com/cgi-bin/mapserv
I get the error:
# safari can't open the page "http://localhost.com/cgi-bin/mapserv" because
the server
# unexpectedly dropped the connection.
and when the URL is accessed this way (leaving /etc/hosts as shown above):
http://localhost/cgi-bin/mapserv
I get the error:
Not Found
The requested URL /cgi-bin/mapserv was not found on this server.
At this point I'm 90% sure the problem lies between safari and apache.
Maybe it's time for a reference manual on apache. Does anyone have any
titles they would like to recommend?
Mike
On Mon, Jan 16, 2012 at 4:14 PM, John Cartwright <
john.c.cartwright at comcast.net> wrote:
> Did you try just "http://localhost/cgi-bin/mapserv" ?
> --john
> On Jan 16, 2012, at 1:11 PM, M Badar wrote:
> Greetings,
> New user to the list. I am installing mapserver on my MacBook Pro. The
> installation has progressed without error until I attempt to call the
> 'mapserv' cgi executable from safari; it returns the following error after
> running the final check as described in the documentation:
> # Page 40, MapServer Documentation, Release 6.0.1; 4.1.8 Installation -
> The basic install.
> # This is the final test to ensure mapserver is installed and functioning
> correctly.
> # When attempting to access the test URL, safari returns the following
> error:
> # Test URL: http://localhost.com/cgi-bin/mapserv
> # Safari error:
> because the server
> Mapserver version: 6.0.1
> Mac OS X version: 10.6.8
> Safari version: 5.1.2
> My suspicion is the error is related to how mapserver and apache are
> communicating; however, not being apache literate, I don't know where to
> begin diagnosing the connection problem. I ran a syntax check on the
> httpd.conf file and it returned the following:
> Michael-Badars-MacBook-Pro:bin bobby$ apachectl -t
> httpd: Could not reliably determine the server's fully qualified domain
> name, using
> Michael-Badars-MacBook-Pro.local for ServerName
> Syntax OK
> The above error is returned regardless if I am connected to the internet
> via a wireless or hardwired connection.
> Listed below are details regarding my installation.
> Thanks in advance for any help you can provide.
> Mike Badar
> # Map Server 6.0.1 "configure" script.
> # Author: Mike Badar
> # Date: 29 December, 2011
> # Version: 3
> ./configure \
> --with-curl-config=/usr/local/bin/curl-config \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-geos=/usr/local/bin/geos-config \
> --with-ogr=/usr/local/bin/gdal-config \
> --with-postgis=/usr/local/pgsql/bin/pg_config \
> --with-xml2-config=/usr/local/bin/xml2-config \
> --with-agg=/usr/local \
> --with-freetype=/usr/local \
> --with-gd=/usr/local \
> --with-httpd=/usr/local/apache2/bin/httpd \
> --with-jpeg=/usr/local \
> --with-proj=/usr/local \
> --with-tiff=/usr/local \
> --with-wfsclient \
> --with-wmsclient \
> --with-threads \
> --with-wcs \
> --enable-debug
> # Mapserver version.
> Michael-Badars-MacBook-Pro:cgi-bin bobby$ ./mapserv -v
> MapServer version 6.0.1 \
> OUTPUT=GIF \
> OUTPUT=PNG \
> OUTPUT=JPEG \
> SUPPORTS=PROJ \
> SUPPORTS=AGG \
> SUPPORTS=FREETYPE \
> SUPPORTS=ICONV \
> SUPPORTS=WMS_SERVER \
> SUPPORTS=WMS_CLIENT \
> SUPPORTS=WFS_CLIENT \
> SUPPORTS=WCS_SERVER \
> SUPPORTS=THREADS \
> SUPPORTS=GEOS \
> INPUT=OGR \
> INPUT=GDAL \
> INPUT=SHAPEFILE
> # Page 39, MapServer Documentation, Release 6.0.1; Step 9 test.
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> # Apache version.
> Michael-Badars-MacBook-Pro:bin bobby$ apachectl -v
> Server version: Apache/2.2.20 (Unix)
> Server built: Sep 12 2011 17:42:56
> # /usr/local/apache2/conf/httpd.conf; mapserver additions.
> # ServerRoot
> ServerRoot "/usr/local/apache2"
> # Apache port.
> Listen 80
> # Cgi directory; ScriptAlias; Log file.
> <Directory /usr/local/apache2/cgi-bin>
> Options +ExecCGI +FollowSymLinks
> </Directory>
> ScriptAlias /cgi-bin/ /usr/local/apache2/cgi-bin/
> # Log file.
> ScriptLog logs/cgi_log
> ErrorLog "logs/error_log"
> # Display user 'www'
> Michael-Badars-MacBook-Pro:~ root# dscl . -read /Users/www
> AppleMetaNodeLocation: /Local/Default
> AuthenticationAuthority: ;ShadowHash;
> ;Kerberosv5;
> ;_www at LKDC
> :SHA1.458017A5A4386C409A25B49470E08467DC7022AF
> ;LKDC:SHA1.458017A5A4386C409A25B49470E08467DC7022AF;
> GeneratedUID: FFFFEEEE-DDDD-CCCC-BBBB-AAAA00000046
> NFSHomeDirectory: /Library/WebServer
> Password: ********
> PrimaryGroupID: 70
> RealName:
> World Wide Web Server
> RecordName: _www www
> RecordType: dsRecTypeStandard:Users
> UniqueID: 70
> UserShell: /usr/bin/false
> # Check /usr/local/apache2/conf/httpd.conf for syntax errors.
> name, using
> Syntax OK
> # Start apache and check for the existence of the httpd process.
> Michael-Badars-MacBook-Pro:logs root# apachectl start
> Michael-Badars-MacBook-Pro:logs root# ps -ajx|grep httpd
> root 526 1 526 59ff000 0 Ss ?? 0:00.18
> /usr/sbin/httpd -D FOREGROUND
> _www 527 526 526 59ff000 0 S ?? 0:00.00
> root 529 391 528 5a00110 2 S+ s001 0:00.00 grep httpd
> The basic install.
> correctly.
> error:
> # Safari error:
> because the server
> # Port 80 /etc/services
> http 80/udp www www-http # World Wide Web HTTP
> http 80/tcp www www-http # World Wide Web HTTP
> # /etc/services
> Michael-Badars-MacBook-Pro:~ bobby$ cat /etc/hosts
> # Host Database
> # localhost is used to configure the loopback interface
> # when the system is booting. Do not change this entry.
> # 127.0.0.1 localhost
> # This line was added in an attempt to diagnose why apache is dropping
> connections
> # to mapserver.
> 127.0.0.1 localhost.localdomain localhost # Mapserver diagnostic
> line.
> 255.255.255.255 broadcasthost
> ::1 localhost
> fe80::1%lo0 localhost
> Michael-Badars-MacBook-Pro:~ bobby$_______________________________________________
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120116/b7e064dd/attachment-0001.html
