[mapserver-users] SOS Configuration
Florence.Tan at csiro.au Florence.Tan at csiro.au
Tue Jan 17 03:32:15 EST 2012
Hi List,
I am new to the list and have been trying to setup MapServer's SOS Server to serve some observation data.  I have created a map file and managed to have GetCapabilities working.  But when trying out the GetObservation, I am confused...  not much helpful documentation around and have found this discussion from the old SOS User forum : http://osgeo-org.1803224.n2.nabble.com/SOS-disconnect-td1992064.html.  However, still confused on how to map a database column to SOS output !?!?
Metadata for the layer in my map file :
 METADATA
 "sos_value_alias"  "value_test"  ## value is the name of the db clumn
 "sos_value_componenturl" "http://test.org#value_test"
 "sos_procedure"   "unknown"
 "sos_offering_id"  "waterstorage"
 "sos_offering_description" "value_test"
 "sos_observedproperty_id" "9"
 "sos_describesensor_url" "http://localhost/TEST123.xml"
 "sos_srs"   "init=epsg:4283"
 "sos_offering_timeextent" "1900/2010"
The database connection is successful and the GetCapabilities return the following sos information :
- <sos:Contents>
- <sos:ObservationOfferingList>
- <sos:ObservationOffering gml:id="waterstorage">
  <gml:description>value_test</gml:description>
- <!-- WARNING: Optional metadata "sos_offering_name" missing for gml:name
  <gml:srsName>EPSG:4326</gml:srsName>
- <!-- WARNING: Optional metadata "sos_offering_intendedapplication" missing for sos:intendedApplication
- <sos:time>
- <gml:TimePeriod>
  <gml:beginPosition>1900</gml:beginPosition>
  <gml:endPosition>2010</gml:endPosition>
  </gml:TimePeriod>
  </sos:time>
  <sos:procedure xlink:href="urn:ogc:def:procedure:unknown" />
- <sos:observedProperty>
- <swe:CompositePhenomenon gml:id="9" dimension="7">
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:feature" />
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:identifier" />
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:ftype" />
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:value_test" />
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:type" />
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:description" />
  <swe:component xlink:href="urn:ogc:def:property:OGC-SWE:1:yearofcompletion" />
  </swe:CompositePhenomenon>
  </sos:observedProperty>
  <sos:featureOfInterest xlink:href="urn:ogc:def:feature:OGC-SWE:3:transient" />
  <sos:responseFormat>text/xml; subtype="om/1.0.0"</sos:responseFormat>
  <sos:resultModel>om:Observation</sos:resultModel>
  <sos:resultModel>om:Measurement</sos:resultModel>
  <sos:responseMode>inline</sos:responseMode>
  </sos:ObservationOffering>
  </sos:ObservationOfferingList>
  </sos:Contents>
GetObservation (http://localhost/cgi-bin/mapserv.exe?map=C:/ms4w/apps/sos/sos_test.map&Request=GetObservation&service=SOS&OFFERING=waterstorage&observedproperty=9&version=1.0.0&responseFormat=text/xml; subtype="om/1.0.0") return the following :
  <?xml version="1.0" encoding="ISO-8859-1" ?>
- <om:ObservationCollection xmlns:gml="http://www.opengis.net/gml" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:sos="http://www.opengis.net/sos/1.0" xmlns:ms="http://mapserver.gis.umn.edu/mapserver" xmlns:om="http://www.opengis.net/om/1.0" gml:id="waterstorage" xsi:schemaLocation="http://www.opengis.net/om/1.0 http://schemas.opengis.net/om/1.0.0/om.xsd http://mapserver.gis.umn.edu/mapserver http://127.0.0.1/cgi-bin/mapserv.exe?map=c:/ms4w/apps/sos/sos_test.map&service=WFS&version=1.1.0&request=DescribeFeatureType&typename=test_sos_layer">
  <gml:description xmlns:gml="http://www.opengis.net/gml">value_test</gml:description>
  </om:ObservationCollection>
My quesions are :
1) How do I map a db clumn to a sos output ??   Do i have to create "sos_dbColumn_alias" for each column ?
2) What's the purpose of "sos_dbColumn_componenturl" ?  Do I need to create this for each dbColumn ?
3) I have map the  "sos_offering_description" "value_test", why does the getCapabilities and getObservation return "value_test" as a constant rather then retrieving data from the database ?
Appreciave if someone could point out what is the problem of the map file or point me to some useful documentation or tutorial on set up SOS in MapServer.
Thanks & Regards,
Florence Tan
Research Projects Officer | ASRDC
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8802 | Fax: +61 8 6436 8559
florence.tan at csiro.au<mailto:florence.tan at csiro.au> | www.csiro.au
Address: Australian Resources Research Centre, 26 Dick Perry Avenue, Kensington WA 6151
PLEASE NOTE
The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
Please consider the environment before printing this email.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120117/c1043743/attachment-0001.html
