[mapserver-users] Help needed with South pole projection issues
Fuchs Juan Carlos
jfuch at indec.mecon.gov.ar
Tue Jan 17 07:54:48 EST 2012
Hi folks!
Please, is there someone, so kind to help me to translate this *.prj to
somewhat (WKT?)
i could pass to Mapserver (projection) to get both maps, one over the
other??
this is my *.prj from the base-layer, so to say.
PROJCS["Transverse
Mercator",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",63781
37.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.017453292519943
3]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",3500000.0],P
ARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-66.0],PARAMETER
["Scale_Factor",1.0],PARAMETER["Latitude_Of_Origin",-90.0],UNIT["Meter",1.0]
this is the snippet in WKT from my *.map file (Projection of the base-map)
PROJECTION
"proj=tmerc"
"lat_0=-90"
"lon_0=-66"
"k=1"
"x_0=3500000"
"y_0=0"
"ellps=WGS84"
"datum=WGS84"
"units=m"
END
This is the *.prj from the shp i have, and need to get along with the other
one.
PROJCS["lambert",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984
",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.01745329
25199433]],PROJECTION["Lambert_Azimuthal_Equal_Area"],PARAMETER["False_Easti
ng",10000000.0],PARAMETER["False_Northing",6391246.5],PARAMETER["Central_Mer
idian",-60.0],PARAMETER["Latitude_Of_Origin",-40.0],UNIT["Meter",1.0]]
that is my best try so far,: WKT from my *.map file layer (Projection)
PROJECTION
"proj=laea"
"ellps=WGS84"
"lat_1=-40"
"lon_0=-60"
"south"
END
what can i say? it displays VERY ugly...
Thanks in advanced for any help/advice you can give me.
JC
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20120117/b1e8fbdb/attachment-0001.html
