[mapserver-users] Resolved: Mapserver install - Mac OS X and
safari
Puneet Kishor
punk.kish at gmail.com
Wed Jan 18 14:18:42 EST 2012
On Jan 18, 2012, at 1:13 PM, M Badar wrote:
> Thanks again to everyone who provided input. The gist of the problem was
> related to a conflict between the version of apache I had installed and the
> version which is shipped with OS X. Listed below are the steps I followed
> to eliminate the problem:
> 1. Completely uninstall the apache version shipped with OS X;
You did the single most possibly wrong thing with #1 above. Never, never touch the stuff that comes with the system if for no other reason than you just don't have to.
> 2. Ran 'find' to search for http occurrences on the filesystem: find /
> -name '*http*' -print;
> 3. Deleted the following file to stop OS X from starting apache
> automatically:
> /System/Library/LaunchDaemons/org.apache.httpd.plist
Good lord. All you had to do was to go to "System Preferences.." and turn off web sharing.
If you really wanted to do it the difficult way, you could have done a `launchctl unload` (http://ss64.com/osx/launchctl.html)
> 4. Start apache manually with 'apachectl'
> /usr/local/apache2/bin/apachectl start
> 5. Access the mapserver URL as follows:
> http://localhost/cgi-bin/mapserv
> 6. Success - the following was displayed by Safari:
> No query information to decode. QUERY_STRING is set, but empty.
> 7. Let the fun begin!
> Although I'm not sure which of the steps above actually fixed the problem,
> I believe it was steps 1 and 3 which were the critical parts of the
> solution.
I hope it works out for you... good luck.
> Take care,
> Mike Badar
> # Original post.
> Thanks, everyone.
> With /etc/hosts set to:
> 127.0.0.1 localhost localhost
> and accessing the URL:
> http://localhost.com/cgi-bin/mapserv
> I get the error:
> # safari can't open the page "http://localhost.com/cgi-bin/mapserv" because
> the server
> # unexpectedly dropped the connection.
> and when the URL is accessed this way (leaving /etc/hosts as shown above):
> I get the error:
> Not Found
> The requested URL /cgi-bin/mapserv was not found on this server.
> At this point I'm 90% sure the problem lies between safari and apache.
> Maybe it's time for a reference manual on apache. Does anyone have any
> titles they would like to recommend?
> Mike
> Greetings,
> New user to the list. I am installing mapserver
> on my MacBook Pro. The installation has progressed without error until I
> attempt
> to call the 'mapserv' cgi executable from safari; it returns the following
> error
> after running the final check as described in the documentation:
> # Page 40, MapServer Documentation, Release 6.0.1; 4.1.8 Installation - The
> basic install.
> # This is the final test to ensure mapserver is installed and functioning
> correctly.
> # When attempting to access the test URL, safari returns the following
> error:
> # Test URL: http://localhost.com/cgi-bin/mapserv
> # Safari error:
> the server
> Mapserver version: 6.0.1
> Mac OS X version: 10.6.8
> Safari version: 5.1.2
> My suspicion is the error is related to how mapserver and apache are
> communicating; however,
> not being apache literate, I don't know where to begin diagnosing the
> connection problem. I
> ran a syntax check on the httpd.conf file and it returned the following:
> Michael-Badars-MacBook-Pro:bin bobby$ apachectl -t
> httpd: Could not reliably determine the server's fully qualified domain
> name, using
> Michael-Badars-MacBook-Pro.local for ServerName
> Syntax OK
> Listed below are details regarding my installation.
> Thanks in advance for any help you can provide.
> Mike Badar
> # Map Server 6.0.1 "configure" script.
> # Author: Mike Badar
> # Date: 29 December, 2011
> # Version: 3
> ./configure \
> --with-curl-config=/usr/local/bin/curl-config \
> --with-gdal=/usr/local/bin/gdal-config \
> --with-geos=/usr/local/bin/geos-config \
> --with-ogr=/usr/local/bin/gdal-config \
> --with-postgis=/usr/local/pgsql/bin/pg_config \
> --with-xml2-config=/usr/local/bin/xml2-config \
> --with-agg=/usr/local \
> --with-freetype=/usr/local \
> --with-gd=/usr/local \
> --with-httpd=/usr/local/apache2/bin/httpd \
> --with-jpeg=/usr/local \
> --with-proj=/usr/local \
> --with-tiff=/usr/local \
> --with-wfsclient \
> --with-wmsclient \
> --with-threads \
> --with-wcs \
> --enable-debug
> # Mapserver version.
> Michael-Badars-MacBook-Pro:cgi-bin bobby$ ./mapserv -v
> MapServer version 6.0.1 \
> OUTPUT=GIF \
> OUTPUT=PNG \
> OUTPUT=JPEG \
> SUPPORTS=PROJ \
> SUPPORTS=AGG \
> SUPPORTS=FREETYPE \
> SUPPORTS=ICONV \
> SUPPORTS=WMS_SERVER \
> SUPPORTS=WMS_CLIENT \
> SUPPORTS=WFS_CLIENT \
> SUPPORTS=WCS_SERVER \
> SUPPORTS=THREADS \
> SUPPORTS=GEOS \
> INPUT=OGR \
> INPUT=GDAL \
> INPUT=SHAPEFILE
> # Page 39, MapServer Documentation, Release 6.0.1; Step 9 test.
> This script can only be used to decode form results and
> should be initiated as a CGI process via a httpd server.
> # Apache version.
> Michael-Badars-MacBook-Pro:bin bobby$ apachectl -v
> Server version: Apache/2.2.20 (Unix)
> Server built: Sep 12 2011 17:42:56
> # /usr/local/apache2/conf/httpd.conf; mapserver additions.
> # ServerRoot
> ServerRoot "/usr/local/apache2"
> # Apache port.
> Listen 80
> # Cgi directory; ScriptAlias; Log file.
> <Directory /usr/local/apache2/cgi-bin>
> Options +ExecCGI +FollowSymLinks
> </Directory>
> ScriptAlias /cgi-bin/ /usr/local/apache2/cgi-bin/
> # Log file.
> ScriptLog logs/cgi_log
> ErrorLog "logs/error_log"
> # Display user 'www'
> Michael-Badars-MacBook-Pro:~ root# dscl . -read /Users/www
> AppleMetaNodeLocation: /Local/Default
> AuthenticationAuthority: ;ShadowHash;
> ;Kerberosv5;
> ;_www at LKDC
> :SHA1.458017A5A4386C409A25B49470E08467DC7022AF
> ;LKDC:SHA1.458017A5A4386C409A25B49470E08467DC7022AF;
> GeneratedUID: FFFFEEEE-DDDD-CCCC-BBBB-AAAA00000046
> NFSHomeDirectory: /Library/WebServer
> Password: ********
> PrimaryGroupID: 70
> RealName:
> World Wide Web Server
> RecordName: _www www
> RecordType: dsRecTypeStandard:Users
> UniqueID: 70
> UserShell: /usr/bin/false
> # Check /usr/local/apache2/conf/httpd.conf for syntax errors.
> name, using
> Syntax OK
> # Start apache and check for the existence of the httpd process.
> Michael-Badars-MacBook-Pro:logs root# apachectl start
> Michael-Badars-MacBook-Pro:logs root# ps -ajx|grep httpd
> root 526 1 526 59ff000 0 Ss ?? 0:00.18
> /usr/sbin/httpd -D FOREGROUND
> _www 527 526 526 59ff000 0 S ?? 0:00.00
> root 529 391 528 5a00110 2 S+ s001 0:00.00 grep httpd
> basic install.
> correctly.
> error:
> # Safari error:
> the server
> # Port 80 /etc/services
> http 80/udp www www-http # World Wide Web HTTP
> http 80/tcp www www-http # World Wide Web HTTP
> # /etc/services
> Michael-Badars-MacBook-Pro:~ bobby$ cat /etc/hosts
> # Host Database
> # localhost is used to configure the loopback interface
> # when the system is booting. Do not change this entry.
> # 127.0.0.1 localhost
> # This line was added in an attempt to diagnose why apache is dropping
> connections
> # to mapserver.
> 127.0.0.1 localhost.localdomain localhost # Mapserver diagnostic
> line.
> 255.255.255.255 broadcasthost
> ::1 localhost
> fe80::1%lo0 localhost
> Not Found
> mapserver-users at lists.osgeo.org
