[mapserver-users] 16 bit PNG or 16 bit jpeg output
Stephan Meißl
stephan at meissl.name
Thu Jan 19 12:46:37 EST 2012
if you omit the mediatype parameter with version 2.0 you definitely get
back only the binary output as requested in the format parameter. In WCS
1.1 afaik you always get back a multipart response and in WCS 1.0 always
only the binary.
cu
Stephan
On Thu, 2012-01-19 at 17:16 +0000, Rahkonen Jukka wrote:
> Hi,
> No way, I mean the WCS version 1.0 as described in the very same document http://www.mapserver.org/ogc/wcs_server.html
> -Jukka Rahkonen-
> ________________________________
> Lähettäjä: Ragi Burhum [ragi at burhum.com]
> Lähetetty: 19. tammikuuta 2012 19:02
> Vastaanottaja: mapserver-users at lists.osgeo.org; Rahkonen Jukka
> Aihe: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
> Hi Jukka,
> I assume you mean WCS 2.0 and that you are referring to the MEDIATYPE directive. The documentation at http://mapserver.org/ogc/wcs_server.html#test-your-wcs-1-0-server said that only "multipart/mixed" was allowed. Am I mistaken?
> Date: Thu, 19 Jan 2012 08:13:54 +0000
> From: Rahkonen Jukka <Jukka.Rahkonen at mmmtike.fi<mailto:Jukka.Rahkonen at mmmtike.fi>>
> Subject: Re: [mapserver-users] 16 bit PNG or 16 bit jpeg output
> To: "'mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>'"
> <mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>>
> Message-ID:
> <84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi<mailto:84446DEF76453C439E9E97E438E13A63063812 at suutari.haapa.mmm.fi>>
> Content-Type: text/plain; charset="us-ascii"
> Hi,
> Could it be possible for you to use WCS 1.0.0 for avoiding the multipart thing?
> -Jukka Rahkonen-
> Ragi Burhum wrote:
> Hello,
> I am trying to output a single band 16bit png (or jpeg) output from a Mapserver WCS service.
> I have tried the following output formats:
> OUTPUTFORMAT
> NAME jpeg
> DRIVER "GDAL/JPEG"
> MIMETYPE "image/jpeg"
> IMAGEMODE INT16
> EXTENSION "jpg"
> FORMATOPTION "QUALITY=85"
> END
> OUTPUTFORMAT
> NAME GDALPNG
> DRIVER "GDAL/PNG"
> MIMETYPE "image/png"
> IMAGEMODE INT16
> EXTENSION "png"
> FORMATOPTION "FILENAME=result.png"
> END
> When I try different IMAGEMODEs, I get the correct results, but for some reason, INT16 does not work. I looked through the mailing list and I noticed that this question has been asked before:
> http://osgeo-org.1803224.n2.nabble.com/16-Bit-PNG-Output-td6249725.html
> http://osgeo-org.1803224.n2.nabble.com/Using-a-16-bit-per-band-PNG-image-td2490088.html
> I tried looking for a ticket in Trac, but I had no luck. Am I doing something wrong? Perhaps I could accomplish this somehow with a custom gdal driver?
> Also, a side question, if I wanted to make sure the replies from my WCS getcoverage calls were not multipart (I am just interested in the binary output), is there some mapserver-specific setting I can use to just get that image as a reply instead of the accompanying xml files?
> Thanks!
> - Ragi
